Fill/Redrill vs Adapters
  • z31maniac
    • 17566
    Just fine on the street, probalby $150-250 depending on who does it.
    www.gutenparts.com
    • z31maniac
      • 17566
      Originally posted by xwill112x
      dooo etttt
      They are for sale, buy them.
      www.gutenparts.com
      • bad_azz_bmr
        • Sep 2004
        • 433
        that isn't very cheap...
        plus the fact your stuck with one set of wheels, if you have the adapters you can run different wheels with the same adapters...
        you can get a good set of used adapters for about $200-$250 on vortex, especially for 4x100 to 5x130 (non interfernce bolt pattern)
        • george graves
          • 20003
          Originally posted by bimma360
          Yeah just off the top of my head, adapters let you run e36 and porsche wheels... that aint bad...
          e36 is 5x120. You need a 2 part adapter for that, and then the minimum spacer size is closer to 40-50mm(?)
          Would e36 wheels even work then?
          Originally posted by Matt-B
          • z31maniac
            • 17566
            Assuming they are the correct thickness for what you need. And if you had to buy new, quality adapters approach $400 for 4.
            According to Matt at Adaptec, that is no longer the case.
            www.gutenparts.com
