Fill/Redrill vs Adapters
  • z31maniac
    • 17566
    What are your thoughts?
    Fill/redrill is cheaper, but I question the safety since it seems most 4x100 redrills start to every so slightly get into the meat of the hub.
    It seems you can get good quality adapters for every bolt pattern -> bolt pattern now, but a pair is going to come in around twice as much as a redrill it seems.
    www.gutenparts.com
    • 34844
    you end up with stupid offsets with adapters. if it's just for the street a fill/drill by a pro shop is fine. if you want track wheels there's no reason to care about bolt patterns, there's lots of cheap/light/strong track wheels already that fit E30s.
    • z31maniac
      • 17566
      Hahaha, the 318 will not be seeing track time.
      www.gutenparts.com
      • Mystikal
        Wheel Fitment Expert
        • 9602
        I disagree. Most of the automotive world runs a 35-50 offset, and that's exactly what you end up at with 20mm adapters.
        • bimma360
          • 1940
          Yeah just off the top of my head, adapters let you run e36 and porsche wheels... that aint bad...
          E30 Dinan Turbo
          • z31maniac
            • 17566
            If no problem redrilling I'll probably go that route.
            Just depends on what wheels I get and what the final ETs will be.
            www.gutenparts.com
            • stinkydriverx
              • Jan 2008
              • 501
              Well the only wheels that will work with a redrill IMO are something with a centercap(Weaves, Borbet type a).
              Anything else unless painted afterwards will look like crap. Im going with adapters personally and like mystikal said, most of the auto world runs 35-50mm offsets. So depending on your bolt pattern you will be golden. With the correct hubsize on the adapter and the right TQ it will be a very safe extension of your hub.
              Turbo m30 drift car build.
              500whp or bust.
              http://www.r3vlimited.com/board/showthread.php?t=256525
              • StereoInstaller1
                GAS
                • 22679
                Buy the damn beyern wheels, screw all that spacer/adapter nonsense.
                Closing SOON!
                Thanks for 10 years of fun!
                • z31maniac
                  • 17566
                  Won't be doing any of it.
                  I decided daily driving a car slammed on RS's with some stretch was going to turn my 50 mile round trip commute everyday into a gigantic pain in the ass.
                  www.gutenparts.com
                  • xwill112x
                    • Jan 2009
                    • 4236
                    lower it slightly, throw some kosei's or some other cheap wheel with meaty tires. win-win situation.
                    • z31maniac
                      • 17566
                      It's funny you should say that.
                      There is 15x7 set of Kosei K1s with 205/50 RT-615s on them in my garage right now for summer/Auto-X tires.
                      ALthough I really want to sell them and put 15x8 TRM C1s with 225/45 Hankook RS-3s.
                      www.gutenparts.com
                      • 3bvert
                        • 1032
                        not intended to be a thread jack, but would the e36 wheels and adapters, make the tires stick out further or would rolling be needed
                        • z31maniac
                          • 17566
                          Depends on width, offset of the wheels and size of the adapters.
                          www.gutenparts.com
                          • xwill112x
                            • Jan 2009
                            • 4236
                            dooo etttt
                            • OOMPH!
                              • 3487
                              What's it typically cost to get 4 wheels filled and redrilled? I never track my car but I do a lot of highway driving at high speeds, safe or not so safe with redrilled wheels?
