KOPI's on the way, two much - camber????
  • hallfleming
    • Dec 2004
    • 29
    i've got the kopi (alpina look-likes) coming today in 17*7.5...
    going to order some springs, shocks/struts, m3 still cambered bushing, and strut mounts.
    here's my question. should i get the fixed offset front strut mount (more negative camber)? is this too much negative camber with this setup? it's a daily driver...
    like always, thanks in advance to all that reply. i'm trying my best to give back to the boards as much as i get from them... :)
    hall
  • Brew
    • 3060
    We'll need to know which springs you are getting and how much of a drop they'll give you before we can start to talk about camber.
    '91 318is
    • Mystikal
      Wheel Fitment Expert
      • 9602
      Yeah, change in wheels /= change in camber.
      • hallfleming
        • Dec 2004
        • 29
        i started to do that, dang it!
        eibach pro's and koni's.. im looking for the actual drop. was told be reseller 1.8 up front and 1.5 in back.
        eibach site shows this: PRO-KIT 1.5 in 1.0 in
        thanks!
        • DanGillan
          • Mar 2004
          • 4061
          you definately dont need to worry about camber, you'll be fine, shit if you want you could stand to have one more degree negative judging by those drop #'s
          Dan
          • hallfleming
            • Dec 2004
            • 29
            thanks for that reply. i like your wheels.. :)
            so m3 bushings and a fixed neg cambered strut mount shouldnt be too much correct?
            • Digitalwave
              is a poseur
              • 6299
              M3 bushings don't change the camber. 1.8" drop doesn't give you much negative camber so you will be fine.
              RISING EDGE
              • hallfleming
                • Dec 2004
                • 29
                thanks for the info...
                i spoke to eibach tech support about their kits.. here's what i found out:
                no sportlines only pro-kit for mine
                progressive not linear for pro-kits
                they said 1.6 drop for front and 1.0 for rear on my 318is
                also 10 to 20% stiffer than a stock ride..
                i told him i always heard eibachs are super low compared to the h&r's. he said that eibachs are softer than the h&r's... weird, (he actually spoke well of h&r's) i assumed that the super duper major eibach drop people talked about had a stiffer ride...and 1.6 doesnt seem to much to me....
                also, i got some konis coming with stock style front strut/mounts and bearings, m3 caster bushings, and e46 rear mounts. i'm thinking i can soften the ride for the 215*40's using the koni's.
                • Mystikal
                  • 9602
                  Everything he said is true. I'll try to explain the stiffness.
                  The Eibach Pro-Kit is a progressive spring, meaning the rate increases the more it is compressed. This lends a much more tolerable ride, as small imperfections don't toss you side to side. It can also help keep the car off the bump stops, as the rate gets very high near the end to prevent it.
                  The H&R Sports are linear. They have the same rate throughout the range, which has tradeoffs. The ride is more jittery, but it lends the benefit of making the car more predictable during hard driving. If you drove a car with linear springs back to back with a car with progressive springs you'd see the difference.
                  The Eibachs lower the car noticeable more than H&R's, possiblity due to the soft initial rates. To me they also provide a more pleasing stance, but that's preference.
