Extended LugBolts - Any Experience with these listed?
  • 95///M3
    • Mar 2005
    • 181
    UltraRev.com is available for purchase. Get in touch to discuss the possibilities!
    Running 15MM spacers all around.
    Thoughts?
  • OOMPH!
    • 3487
    Damn that's pretty cheap... $0.83 each
    But I don't understand what you're actually asking, thoughts if those would work or thoughts on extended lugbolts in general?
    • 95///M3
      • Mar 2005
      • 181
      Wanted to make sure that they would work and if anyone has actually ordered from that site before?
        • 34836
        don't waste money on 83 cent bolts, unless you want them to fail. If you want quality, longer bolts, go with a stud kit. Not the cheap chrome ones either, get the black ones with rolled threads.
        It's not fun when 3 out of 4 bolts/studs on a wheel break. It's happened to me before, I'll never buy cheap wheel hardware again.
        • dude8383
          • Jan 2005
          • 10387
          The only thing that upsets me about the stud kits available now is that you can't rock center caps with em.
            • 34836
            it depends on if you're using spacers and how thick they are though.
            • dude8383
              • Jan 2005
              • 10387
              Heh, you're right, i should have mentioned that...i have 15mm spacers in the back and had to shorten my studs somewhat to get the caps to fit. The fronts are/were the shorter kit that Vorshlag used to offer.
