Miata Wheels?
  • LennysEleven
    • Mar 2004
    • 163
    Miata Wheels?
    Do Miata wheels fit our cars? Ive read that some of their stock wheels are extremely light.
    thanks
    Nick
  • Chris E30 Cab
    • 866
    Same lug pattern, different centrebore & very high offset (ET40'ish)....I'm pretty sure the Miata centrebore is larger so a centering ring can be used and some 15-20mm spacers should get you going....perhaps a stud conversion too.
    We have some 15" Enkei RPF-1 rims on our Miata and they only weigh 9lbs each :shock: It's the same looking rim that the McLaren F1 team uses. The stock wheels are also light, appx 11lbs for their 14" from the Mk1.
    • Jand3rson
      • 37587
      I was looking at 16" Kosei K1's in Miata fitment for my E30 on TireRack. They would need a 10mm spacer, but overall that was it as far as mounting them.
        • 34847
        josh, there are 16x7.5" K1s that will fit without any spacer. Tirerack has blanks with the proper offset, they just drill for your bolt pattern and center bore.
        • Jand3rson
          • 37587
          EXCELLENT.
          • B3ND3R
            • Apr 2005
            • 71
            Same bolt pattern - 4 x 100.
            Stock Miata offset is et38 - et40.
            Problem is the centerbore. Miata is the smallest of any mass-produced car @ 54.1mm. The MR2 centerbore is the same as well. So, you will have to get someone to machine out a Miata/MR2 wheel to 57.1mm (about $40/wheel last time I checked) if you want to use it on the e30, and then you will have to use a spacer to get it back to the et25 range.
            Bottom line is it can be done, but you are usually better $$$ wise to just get a proper offset and centerbore for the e30.
