Looking for some new wheels for track days
  • Nick325is
    • 1409
    I am looking for some new wheels for my e30 to run for autox and HPDE. I am in the market for 16 inch wheels that will hold 245s all around. I have looked at diamond racing wheels and other than that I haven't found anything of much interest other than some 3 piece panasports which are quite expensive.
    Anyone have any ideas?
    Nick
    Clearance will not be an issue :twisted:
  • Brew
    • 3060
    16x8 Kosei K1 blanks, drilled for 4x100
    You can get them at tirerack, but i think you'll have to call them.
    or
    CCW wheels. Very reasonably priced for totally custom,3-piece forged wheels, very light and they look damn good too. And you can get 16x16's if you want.:twisted:
    '91 318is
    • Nick325is
      • 1409
      So 16x8s will be fine with 245s? If so I may just go with the diamond racing wheels.
      Nick
      • permit
        • Mar 2005
        • 3363
        The 16x8.5 cost $209 a wheel, the 15x8 cost $199 a wheel.
        • Nick325is
          • 1409
          My other question is what offset should I get to avoid rubbing on the struts? My car will have konis with GC all around. The fenders are also rolled way out so they shouldn't be a problem.
          Nick
          • Jand3rson
            • 37587
            Droooool....
            I would love to get those. But suspension first, then wheels. :up:
            • Brew
              • 3060
              et15 would be a safe bet, but you could run et20 all around and then add spacers up front to clear the struts. The rears can handle higher offset IIRC.
              '91 318is
              • alex
                • 2024
                CCW wheels. Very reasonably priced for totally custom,3-piece forged wheels, very light and they look damn good too. http://ccwheel.com/
                So what does "very light" mean?
                Also with ET15 on 9" wide rim the front will rub on the strut, with 1/4" spacer and 245/45/16 Hoosiers the tire will rub on the strut.
                • ragehardintothebendies
                  • 50
                  From Tirerack
                  15X7 BLANKS ET17 SIL K1 RACING * $179.00
                  15X7 BLANKS ET27 SIL K1 RACING * $179.00
                  15X7 BLANKS ET38 SIL K1 RACING * $179.00
                  15X7 BLANKS ET45 SIL K1 RACING * $179.00
                  15X8 BLANKS ET12 SIL K1 RACING * $199.00
                  15X8 BLANKS ET22 SIL K1 RACING * $199.00
                  15X8 BLANKS ET32 SIL K1 RACING * $199.00
                  16X7.5 BLANK ET12 K1 RACING * $199.00
                  16X7.5 BLANK ET22 K1 RACING * $199.00
                  16X7.5 BLANK ET32 K1 RACING * $199.00
                  16X7.5 BLANK ET43 K1 RACING * $199.00
                  16X8.5 BLANK ET17 K1 RACING * $209.00
                  16X8.5 BLANK ET27 K1 RACING * $209.00
                  16X8.5 BLANK ET37 K1 RACING * $209.00
                  17X7.5 BLANK ET35 K1 RACING * $239.00
                  www.islandmma.com
                  • Brew
                    • 3060
                    Well, they are "very light" for a strong, 3-piece rim, from what I've gathered. They don't list weights on their site, but I have found a few examples over on bimmerforums, as a bunch of the track/auto-x junkies run them.
                    18x10s, 19lbs <--- Pretty damn light if you ask me.
                    Here's another thread. This guy's 17x9s were 16lbs apparently.
                    Not sure where that would put a 16x8, but I would guess that it would be around the 15lb mark.
                    Sure SSR Comps are lighter, but I've heard complaints that they bend easily. Plus, they aren't available in a 16x8, 4x100.
                    EDIT: Actually, at least in 18x10s, the CCWs are lighter. According to tirerack, 18x10 SSR Comps are 19.9lbs.
                    '91 318is
                    • Nick325is
                      • 1409
                      I am looking at running 245/45/16s so should I go with the 8 inch rim?
                      Nick
                      • Brew
                        • 3060
                        245s will fit well on an 8" rim.
                        '91 318is
                        • Nick325is
                          • 1409
                          Sounds good. I am looking at the steelies on diamondracingwheels.com. They only offer wheels in backspacing instead of the mm offset i am used to. What backspace would be good for my setup?
                          Nick
                          • Bill 84 318i
                            • 1600
                            Nick
                            Nobody's gonna know off hand. Just use a ruler, long straight edge (enough to go up to where the wheel would contact the strut) and a little logic.
                            • thejimlab
                              • Oct 2004
                              • 588
                              Nick
                              check this out
                              The 15x7 ET27 Kosei's in my picture for instance have exactly 5-1/16th" of backspace, which is a teensy bit too much when using a 225/50-15. A better backspace would be exactly 5" even, because as it is my Left Rear inner sidewall sometimes rubs in extremely hard cornering, but otherwise don't touch.
                              taken from the dirty3e0 website
