balancing wheels....again?
  • bmw325csi
    • May 2007
    • 4045
    I just got some spacers for my front wheels which were perfectly balanced but now it seems they are out of whack a bit since I get vibrations @ 50-60mph range. I was wondering how they need to be balanced. Does the spacer and wheel get balanced together or do my wheels need another balancing?
    On another note, my wheels were et20 before and now that they have 15mm spacers, what is the final offset?
    harry/harout
  • widebodye30
    • Jan 2006
    • 3407
    Your et now will be +5mm. The wheel should not be balanced with the spacer. Try balancing the wheel again maybe?
    www.esmwheels.com
    www.dtmfiberwerkz.com
    Toll Free: 800.729.5450
    Local: 818.341.9903
    • Philo
      Ich esse kleine Kinder
      • 3334
      Final offset is et5. As far as the vibration goes, I would check to make sure lugs are evenly torqued to the correct tension and mounting surfaces are clean. Are you running hubrings/hubcentric?
      -tim
      Originally posted by Jordan
      I like the stance
      • bmw325csi
        • May 2007
        • 4045
        nope they wheels are e30 specific, so are the spacers, so i guess they are hubcentric
        harry/harout
        • bmw325csi
          • May 2007
          • 4045
          thanks Ary, the spacers look great, not hella flush but nice and flush
          harry/harout
          • Jand3rson
            • 37587
            How in the hell would you balance a wheel WITH a spacer?
            • bmw325csi
              • May 2007
              • 4045
              jees Janderson, now I know.
              you could actually mount the spacer and the wheel to the balancer and do it that way could you not?
              harry/harout
                • 37829
                Does the spacer fit snugly around the E30 hub? Does the hub lip ON the spacer fit perfectly in to the wheel? If there is any gap in either of these your problem is explained.
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • bmw325csi
                  • May 2007
                  • 4045
                  one of the spacers was actually a tight fit, the other was good. Im going to ask Castro if he had any trouble when he installed it
                  harry/harout
                    This sounds like a poor fit of the spacer to the centering ring on the hub or a poor fit between the centering ring on the spacer and the wheel. Hubcentric clearances must be a close sliding fit or there'll be problems with vibration.
                    • Holland
                      • Nov 2008
                      • 7178
                      I had this problem with my 10mm H&R spacers on my enkies and bottlecaps, hubcentric. Next time I see studs and non hubcentric sacers in my life, much less hassle.
                      Originally posted by DEV0 E30
