Thinking of building my own steel wheels, What size???
  • MonkeyMadness
    • 3251
    Originally posted by e30_325es
    If you make them 16x7.5, run a real tire and do a 225/45.
    I'd do 8" in a 15 or 16. Run 225's in either size.
    Originally posted by Philo
    I'm down with a 225 as well. It's all about personal preference.
    I like the look of that... 225-45-16 on a 8" with 0 offset
    that looks good.. gives me 2" more on the lip side and doesn't
    interfere with the suspension as it's the same back space as the stocker
    and it doesn't look like it will change my ride height to much...
    I've been using the link below
    http://www.willtheyfit.com/index.php?width=195&aspect=60&diameter=14&wheelwid th=6&offset=25&width2=225&aspect2=45&diameter2=16& wheelwidth2=8&offset2=0&Submit=Submit
    and a 195-45-16 on 7" with 15 offset giving me a little stagger and tire stretch or even a 205
    http://www.willtheyfit.com/index.php?width=195&aspect=60&diameter=14&wheelwid th=6&offset=25&width2=195&aspect2=45&diameter2=16& wheelwidth2=7&offset2=15&Submit=Submit
    Now I just need to pick up some doner rims and get cutting...
    • Philo
      Ich esse kleine Kinder
      • 3334
      and it doesn't look like it will change my ride height to much....
      On a 16x8 wheel you want to shoot for a offset of 20 to comfortably and easily fit 225/45s.
      -tim
      Originally posted by Jordan
      I like the stance
      • MonkeyMadness
        • 3251
        Why?
        20 offset pushes the wheel in, and I don't want any issue with the suspension / wheel rub. I'm willing to roll the fenders and have a little tyre stretch if needed...
        • Philo
          • 3334
          Why?
          Because 16x8 et 20 with a 225/45 fits with very little fender rolling (if any) and doesn't hit the strut housing. With the offset you are talking about you'll be doing more fender work than you want and your front will poke out a bunch.
          Visual example. This is with 16x8 et0 and 195/45. rolled fenders as well.
          -tim
          I like the stance
          • MonkeyMadness
            • 3251
            OK so...
            Front: 195-45-16 on 7" with 20 offset
            Rear: 225-45-16 on 8" with 20 offset
            this work?
            • Philo
              • 3334
              That will work.
              If I was building them, I would make a square set of 16x8 et20 and run 225/45. That way it is still possible to rotate the tires.
              -tim
              I like the stance
              • brandonj1
                • 318
                are you going to post a build thread? im curious...
                • MonkeyMadness
                  • 3251
                  Well I found a set of mini cooper steelie 16x5's and was thinking of picking them up
                  and cutting off the 5" hoop and welding on a much wider set..
                  This will make it easier to turn the hubring out..
                  I can make my own fixtures and stuff at work, as well as do all the welding..
                  If I do decide to do them I will post a build..
