Keizer FSAE Wheels 13"
  • KennyT
    • 542
    I have a set of these left over from a old formula car. I also happen to have newer Hoosier slicks mounted on them. Issues: they are drilled for 4" (101.6mm) bolt circle and will not mount up and the offset is somewhere in the 30mm range so I would have to get some spacers. They would be used for Autocross as they would shorten the ratio to over a 4.10.
    I haven't had a chance to test mount these but do you think they would work, and are they worth the work to get machined?
    • 34844
    13" wheels do not fit over E30 brakes. not unless you run like a -3" offset..
    sell them, get some stock 14x6.5" basketweaves and 225/50-14 hoosiers.
    • KennyT
      • 542
      I wasn't sure how large the calipers ran. They fit over 10" Saturn S brakes so I was hoping they would work. Too bad, free 11lb wheel+tire assemblies would have been sweet.
