Cheapest place for spacers
  • HarryPotter
    • Jan 2010
    • 3642
    I wanna get some pretty thick spacers, 20/25 f/r. Is there any cheap places to pick some up? I know I'll also need lugs.
    John F. Kennedy
  • F34R
    sLaughter
    • 12376
    First off what rims are you running and what is the ET?
    He does a great job and serves the r3v members. You will not be upset, and if you go cheap you will need hub rings to center the rims. Rob's spacers have them machined in to solve that issue.
    I would go with racing studs:
    http://www.turnermotorsport.com/html..._ID=TWH9950B62
    ~Brandon
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • HarryPotter
      • Jan 2010
      • 3642
      Those are a good price too. Thanks dude.
      What do you guys think would be a good size for spacing stock 14 inch weaves out?
      I was thinking 20mm in the front and 25 in the back?
      John F. Kennedy
      • motorsports_3
        • Mar 2007
        • 1058
        Velocity motorcars also has some good deals.
        • Danny
          • 14216
          40mm spacers.
          • F34R
            sLaughter
            • 12376
            I would not space stock 14" weaves. Save the coin and spend the money on rims, that is my .2 cents.
            40 front 50 rear is what Danny ment to say.
            Current cars:
            ~ '87 535
            ~ '06 X5 4.8is
            • HarryPotter
              • Jan 2010
              • 3642
              well 140 bucks compared to around 600-700 dollars is a hell of a lot cheaper. KAmotors spaced his bottlecaps and they looked ten times butter than stock.
              Anyone know the stock offset of the 14 inch weaves?
              John F. Kennedy
              • ak-
                • 12422
                Stock et is +30.
                1991 325iS turbo
                • Danny
                  • 14216
                  ONE HUNDRED millimeters.
                  • F34R
                    sLaughter
                    • 12376
                    FUCK YOU DANNY! I raise you with 120mm
                    Current cars:
                    ~ '87 535
                    ~ '06 X5 4.8is
                    • F34R
                      sLaughter
                      • 12376
                      Stock weaves are poop even poked IMO
                      mmm, butter xD
                      Current cars:
                      ~ '87 535
                      ~ '06 X5 4.8is
                      • ak-
                        • 12422
                        ONE HUNDRED millimeter spacers.
                        Is basically what you need.
                        1991 325iS turbo
                        • txtorquemade
                          • 1758
                          Are you kidding? 100mm?
                          Thinking about spacing my stock weaves too. Seriously now... 100mm?
                          sigpic 1987 325is
                          • Massive Lee
                            • Sep 2006
                            • 6785
                            I think that Danny is trying to make "somebody" understand how inaccurate his tech info is. Centering rings on 14" BMW BBS? Yeah, sure... :giggle:
                            40, 50mm spacers? Sure, if you want to go Mexican-style with tiny wire wire rims. HarryPotter, don't listen to this self-entitled expert. No wonder he fears his own e30 :mrgreen:
                            Most likely, from the original et30, you want to bring the wheels down to around et13. Therefore, a 15 to 20mm hubcentric spacer will do.
                            massivebrakes.com
                            • F34R
                              sLaughter
                              • 12376
                              Never said I am an expert, I am building a set of BBS RS 3 pieces. So I have a good idea on fitting rims.
                              If you take the time to read the first post you will see that he did not list the rims he is running. And again if you take the time to read and notice that I mentioned the CB only once because I did not know what rims he was planning on.
                              Since the rims are listed and they will not need that much spacing he will be fine with egay ones.
                              40-50 was a joke, kinda funny that you could not make that out.
                              But with 20mm that is only a tiny bit more than 3/4 of an inch. There will be more than enough of the BMWs hub to line it up.
                              Current cars:
                              ~ '87 535
                              ~ '06 X5 4.8is
