my bootle caps are stuck to the rear hub
  • Dominick
    • Aug 2004
    • 323
    WTF, im trying to put my new wheels on and i cant get my rear pax side rim off. i got the lugs off,but its stuck on there.
    i have rear drums and i have my rear wheel bearing and half shafts were changed on it about 2-3 months ago. I soaked it in wd-40, but notthing.
    Any tips
    www.ThundaCats.com
  • StereoInstaller1
    GAS
    • 22679
    First, quit using WD-40 as anything but a water repellant. It really is useless as a penetrant.
    PB Blaster is the shizz as a penetrant.
    Second, whack that fucker!
    Good luck,
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • MattE30
      • 1520
      Good luck,
      Luke
      Use a rubber mallet and hit the shit out of it.
      97 Cosmos M3
      • Jordan
        • 12916
        Its really best if you just sit on your ass in front of the wheel/tire and put both feet on the tire, one on each side.
        Then make alternation kicks with the bottom of your foot.
        https://mtechniqueabs.com/
        • Dominick
          • Aug 2004
          • 323
          yeah i tried kicking it, but it doesnt feel safe with my jack and jackstand. i guess ill just wait until i have time to go to friend to let me get on the lift in his automotive class, then start kicking the shit out of it.
          www.ThundaCats.com
          • code-
            • Aug 2004
            • 20
            Just loosen it a bit and drive a few meters
            • DarkWing6
              • Apr 2004
              • 7144
              So you get underneath a car on a jackstand that you don't think will hold your car? :shock:
              • var1ant
                • Apr 2005
                • 509
                I wouldn't kick a car while someone was under it.
                '87 alpine white 325is
                • DarkWing6
                  • Apr 2004
                  • 7144
                  What about a rusty bolt or something that is stuck....what do you do then? If I couldn't shake the car (kick the tires) a little I wouldn't get under it.
                  • Pedro
                    • 965
                    lay a spare under the car that way if it does fall after you kick it, it falls on the wheel and not the ground directly.
                    http://www.volkswagenjettacup.com/
                    • Digitalwave
                      is a poseur
                      • 6301
                      PB Blaster works wonders, spray it on liberally and leave it overnight if needed.
                      RISING EDGE
                      • Jand3rson
                        • 37587
                        Bootle caps? That made me laugh out loud, very nice. :D
                        • enercity
                          • May 2005
                          • 348
                          like people have already said, hit the back of it with a rubber mallet or kick it.
                          • e30evolution
                            West Werks
                            • 1888
                            i put one lug back ( a few threads) and and beat the shit out of it
                            http://www.westwerksauto.com
                            • Dominick
                              • Aug 2004
                              • 323
                              i got it off finally last night and was able to put my rear rims on.
                              it wasnt stuck due to rust, b/c it easily seperated off the hub and spun freely. the part of the hub the sticks out (i have rear drums) was not perfectly round. i think when i had that side rear wheel bearing they must have warped it somehow.
                              But anyways i had to take my dremel out with a metal file bit and grind inside the bottle cap and just continued to yank on it and that resulted in me smaking myself in the face with my hand and a bottle cap rim :oops:
                              im guessing i can replace that cover on the drums and have a good round hub?
                              www.ThundaCats.com
