tire size question
  • zerokid5555
    • 270
    tire size question
    My 89 325i has two new falken ziex ze 502 205 40 16 in the front and bald falkens in the back. There on Lenso BSX which i beleive are 16x7.5. I cant seem to source the falken 502 - 205/40/16.....Should i just try and by the same size tire in the back and call it a day or would you suggest purchasing a different tire size? Any tire recommendations ?
  • Kershaw
    • 11822
    http://www.nlmotoring.com/Falken-ZE-...-205-40-16.htm
    how are you not finding them? i literally just highlighted and googled the tire name and size in your message....
    never mix and match tires. different brands will be slightly different sizes and different tire compounds will lead to unpredictable handling.
    its always best to replace all 4 tires at the same time. however, it is acceptable to replace the fronts or rears independently providing the non-replaced set is in good shape. better tires always go in the front, because you do most of your braking (and turning) with your front tires.
    AWD > RWD
