Dumb Wheel Question
  • CJG
    • 51
    Dumb Wheel Question
  • FredK
    • 14762
    That is a 7.5" wide, 17" tall wheel.
    BBS has their own line of hubcentric rings. Call Tire Rack to get the appropriate centering ring for the spacers you plan on running. In your case, the spacers will likely be 57.1 mm.
    • Dj Buttchug
      • Jun 2010
      • 7685
      yup those are 17s
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • RainierHooker
        • Jul 2009
        • 2026
        Probably around a 225/40 or so, I'd check the wheel-n-tire fittment thread for more info. Or hit up Mystikal.
        Also, if they are in fact an ET of 42, you are gonna need around a 20mm spacer with those.
        1984 Hennarot 325e - 1990 Brillantrot M3 - 1938 Buick Special Business Coupe
        • Jb325is
          • 2137
          Those are 17's for sure
          - '88 m54 coupe
          <3
          • Jb325is
            • 2137
            I would try to sell them, you will need a 25mm spacer and you could probably run 215/40/17 with no problem. 225/40 would be perfect but unfortunately that size is impossible to find in 17"
            - '88 m54 coupe
            <3
            • blefevre
              • Dec 2008
              • 4287
              Take it to a tire shop. Most should have rings. Ask nicely and they probably will just use trial and error until you get the right one.
              - E30, DSM, Golf R, Mazda 3 Skyactiv
