How will I fit this...
  • blck325is
    • Apr 2006
    • 1749
    I have a early coupe which will soon be dropped on a JOM coilover kit. I want to run some 16x8 5 lug wheels with et +5 in the front and I think et +24 or 26 in the rear. I intend to keep the 4 lug. I want to know what size tires I can run and what size adapters I will need to get them enough clearance for the brakes in the front as well as flush all around. I know I might have to roll my fenders. Thanks.
    Originally posted by csermonet47
    Vlad, you are handling this quite unprofessionally.
    Also, you are a cock with tacky taste.
    That is all.
  • constructor
    • Aug 2007
    • 977
    Might have to roll your fenders? You may have to remove your fenders to run 8" et5 + adapters in the front.
    • blck325is
      • Apr 2006
      • 1749
      Damn, know what I think i'll just take pics of the back of the wheel cause I might have deciphered them wrong..
      That is all.
      • einstein57
        • Jun 2007
        • 10780
        if your planning on running style 5s they are et23. The smallest spacer you can get for adapters is 19mm which would give you et 4 out back which is very doable. You'll have some poke in the front though. You could fill and drill just the fronts and run a 5mm spacer and grind the clip a little. 205/50/16 fit nice. 45s have a stretched look.
        www.gecoils.com
        • VicSkimmr
          • 687
          16x8 et 5 in the front and 16x8 et 24 in the rear is going to look odd.
          Jason
          flickr
          • blck325is
            • Apr 2006
            • 1749
            Ahh I really cant fill and redrill these because of their resale value. Hmm, so theres no way to run the fronts without the fill and redrill huh..damn. Theres a very good chance I am compeltely retarded and read the wheels wrong. They're work ewings in 16x8, well I think they're all 16x8. I will investigate further in the next day or two.
            That is all.
            • daniel
              • 6703
              I prefer the no fender look.
              http://instagram.com/dslovn.drives
              • jp_slick
                • 1089
                they wont fit, should give them to me.
                89 325i S50/ZF E36 M3/TI 5lug Style 32s
                My feedback Thread http://www.r3vlimited.com/board/showthread.php?t=219113
                • 416stroker
                  • May 2008
                  • 2448
                  are they one piece or two?
                  84 318I Delphin RIP
                  87 325IS delphin 24v Sold
                  89 325 Alpineweiss
