Tires for 15x8 BBS RMs
  • royalflush313
    • Mar 2004
    • 2070
    Just wanted to know if anyone here is running some 15x8 (2" lips) BBS RMs in their E30s, and if you experience any rubbing.
    225/50/15s is one option, but I'd be wary about the rubbing.
    Pretty much, I'd like to know the widest tire I can fit without fender rolling (on a moderately dropped car).
    I believe the wheels are ET15.
    ~ Go Canucks Go! ~
  • PeterCip
    • 402
    Re: Tires for 15x8 BBS RMs
    I run 225 /50/15 's on a 15x7.5" wheel with a et22.
    the car is dropped quite a bit and doesn't rub.
    if that helps you at all..
    • Mystikal
      Wheel Fitment Expert
      • 9602
      Even with 205/55/15's you'll be right at the fender.
      • royalflush313
        • Mar 2004
        • 2070
        so with a 205/55 do you think that I can make it without rolling the fenders?
        ~ Go Canucks Go! ~
        • royalflush313
          • Mar 2004
          • 2070
          anyone know?
          ~ Go Canucks Go! ~
          • Mystikal
            • 9602
            Nope, you'll still need to roll a good bit.
            • Erick
              Official R3V Drifter
              • 11169
              You'll probably rub for the fact they are ET15s so they will be pretty close to the fender.
              ..::Support FullOpp::..
              FullOpp Stickers for sale!
              Feedback Thread
              • royalflush313
                • Mar 2004
                • 2070
                well i think its around there. The stock RMs are ET33, and then the 15x8s have an additional 1.5" that sticks out on the outside. I'll see how it goes.
                ~ Go Canucks Go! ~
                • e30evolution
                  West Werks
                  • 1888
                  16x9's are et10 in the front.... no rubbing
                  et15 in the rear.... no rubbing, unless i go all the way down
                  http://www.westwerksauto.com
                  • royalflush313
                    • Mar 2004
                    • 2070
                    what suspension setup, and what size tires?
                    Sounds like 15x8 et15 with 205s would be okay then.
                    ~ Go Canucks Go! ~
                    • e30evolution
                      West Werks
                      • 1888
                      i got 215/40's
                      groundcontrol coil overs
                      the rears on your car will be fine..... the fronts on the otherhand may need a small spacer
                      • Mystikal
                        • 9602
                        i got 215/40's
                        You're not rubbing because of the undersized tires, and I know you're aware of that. If he ran 205/50 or 205/45, he would be safe too.
                        Proper sized tires look better to me, but it's a personal preference I suppose.
                        • Digitalwave
                          is a poseur
                          • 6299
                          Run 225's and roll your fenders.
                          RISING EDGE
                          • E30SRPower
                            • Dec 2004
                            • 199
                            Cut the fenders. I did on my toyota.
