Can a 225 width tire fit on a 7" rim?
  • ilia
    • May 2005
    • 194
    I am thinking of buying some new wheels, that are 7" wide. I have 225/45/16 AVS ES100's that I would like to throw on them. Will it fit?
  • redcarbon
    • Apr 2005
    • 213
    it will fit, you just may have some rubbing issues from the wider rubber. My jetta came stock with 225s on 7 inch wide rims.
    318is -gone-
      • 34844
      sure, although the contact patch will be smaller than they would be on a larger rim, and you won't have as much sidewall support.
      • joshh
        • Aug 2004
        • 6195
        The rim width range on that tire is 7-8.5.
        "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
        ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
        • Addissimo
          • Mar 2004
          • 1820
          I have 225/45-16 on my car on a 7" et40 wheel with 15mm spacers. You could probably get away with 11-12mm spacers without rubbing problems on your strut... err... thats at least my experience. If i had more of a drop I'd be ripping the shit out of my unrolled fenders. You just want to stick around 25mm offset.
          -Addis
          Doing something M50 related? -> http://www.addissimo.com
          On Myspace? ->http://groups.myspace.com/r3vlimited
          BF2142 SN = BillyGoose
