I run filled + drilled 16x8 Style 5's with very small (5mm) spacers, 205/45/16 595 RS-R's (they run as 215mm wide). They fit fine and look amazing. Pretty low too.
16x8 "style 5?" rims. Redrill or adapters?
RIP: Delphin '89 E30 with S50 swap and lots of goodies :'(
Then: '04 Evo 8 RS, 500 whp/420 wtq 2900 lb E85 AWD turbo shits 'n giggles
Now: 2003 BMW M5 in Sterling Gray -
There is nothing wrong will a fill and drill if done right.Comment
I would definitely prefer this method because I like the look of the wheels capless and with adapter you can run capless with out the funky looking redrill.
Originally posted by SpasticDwarf;n6449866Honestly I built it just to have a place to sit and listen to Hotline Bling on repeat.Comment
I've been weighing this for about 2 years for my 88 and i'm going with the adpters from 8380 (draft 42) 18mm front 20mm rear finished offset +5 and +3. I took a few shots of a car at the "Vintage" running this set up and will try to post those tomorrow.
This looks like the best set up and in my opinion the safest.Imported from DetroitComment
adapters!! that way u can run multiple wheels and not have to redrill every set of wheels u might like.1989 325i SETA stroker [delphin] R3V'd 8/31/2011
1989 325ix [zinnoberrot] $OLD
1970 2002 [Nevada]
Originally posted by Herr Faust Schinkenguy must have slid into something that doesn't look like a car vs car hitOriginally posted by ak-Must of slid into RobComment
You think redrilled style 5s, either 16"cast, or 17" splits would not be strong enough for an s50 e30?I purchased a set of re-drilled style 5's in 16x8 and to be honest, it was sketchy, though it was done professionally with inserts it was just too thin in the center, so I then sold it to my friend with an integra since he doesn't have enough power to break them. lol
I'd run spacers before I do re-drills. A 5 lug swap is also another option :)
I was hoping to go this route for money sake :(Comment
Don't know the suspension he is running maybe the owner will post his specs.Imported from DetroitComment
