DIY Bent Wheel Repair ?
  • Simon S
    • Oct 2004
    • 3758
    I have a set of 15” weaves – but at least three are dinged as pictured below. (that’s the worst one)
    Has anyone ever straightened out a bent wheel themselves?
    I’ve seen shops with fancy tooling that get wheels to a NASA-straight condition – and I’ve heard about shops with JimBob out back with a hammer and torch.. if JimBob can do – I suppose I can too.
    I’ve seen DIY guides where you heat the bent area with a torch – and then rest a chunk of wood on the bend and strike it with a big hammer. Has anyone ever done this?
    With a tire on it – I don’t think a wheel needs to be NASA-straight – because I’ve seen plenty of dinged up wheels that hold air, and run/drive just fine.
    Part of me wants to make refinishing these wheels a DIY project – which is fine and dandy – but I don’t want to be doing something stupid to these otherwise ‘saveable’ euroweaves.
    Any thoughts or guidance appreciated.
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
  • Hick
    • Sep 2005
    • 6451
    nope
    Originally posted by vlad
    • Simon S
      • Oct 2004
      • 3758
      What's the worst that could happen?
      • george graves
        • 19997
        It could explode and unleash the demons of hell?
        (you can move the metal a bit with a BFH and a block of wood.)
        Originally posted by Matt-B
        • Joe G
          • 2942
          tie like 98766544678lbs onto that side that is bent, then spin the wheel really really really fast. Gravity will do the rest.
          Current Car: 2011 BMW 135i, M-Sport, 6 speed
          Originally posted by lambo
          Sounds like you need a massage.
          Originally posted by kpeng
          Who the hell is Vlad?
          • Axxe
            • Aug 2004
            • 3355
            Propane, torch, block of wood, bfh, beer.
            Keep it slideways!!
            • Streichholzschächtelchen
              • Jan 2009
              • 1670
              two blocks of wood, a small bottle jack and a lot of spinning
              Jah bless! :pimp:
              • geezerman402
                • 213
                Check to see if the wheel spins straight or is warped first. A ding like that might warp a wheel, might not.
                • BrettsE30
                  • Feb 2011
                  • 306
                  Spin it first to make sure the whole wheels not outta whack. I just smacked the crap outta my bottle caps to make em straight but all my bends were on the inner lip.
                  I need your obd1 parts! Harness intake ecu etc.
                  E30 Your Daily Money Pit
                  • george graves
                    • 19997
                    I'd spin it.
                    • Simon S
                      • Oct 2004
                      • 3758
                      Thanks guys.
                      I guess my first step is to spin them and check for warp/wobble.
                      Should be able to mount them as pictured - and set up a guage to check them out.
                      If i'm lucky - and bends are localized to lip areas - then I'll go for it.
                      • BoxDriver86
                        • Jul 2009
                        • 912
                        Method I used on a bent bottlecap. I just wanted to see if it works and it did.
                        Firstly, this is NOT a dig at anyone,,,, if you have a imperfection, ie; flat spot. that you want to repair. . you will need; 1: a bottle jack. 2: heat gun. 3:
                        Other options:
                        BFH - http://www.youtube.com/watch?v=aAsYm...eature=related
                        How the pros do it in case you find a way to replicate - http://www.youtube.com/watch?v=FNa5RmO-UDs
                        Best of luck saving those!
                        • der affe
                          Technical
                          • Dec 2005
                          • 8452
                          I'd spin it.
                          Thanks George, that made my morning.
                          • 8380 Labs
                            • Oct 2006
                            • 2990
                            i've been told by knowledgeable people that heating an aluminum wheel up with a torch will change the properties of the metal and anneal it in a way that could be detrimental.
                            8380 Laboratories
                            M3 Champs Poster
                            • frankenbeemer
                              • Sep 2009
                              • 2260
                              ASM Handbook Volume 2, Properties and Selection: Nonferrous Alloys and Special-Purpose Materials has the following information:
                              356-T6: aging at 305 to 315 °F for 2 to 5 hours
                              Yield stress = 185 MPa
                              Ultimate stress = 262 MPa
                              Fracture strain = 0.05
                              356-T7: aging at 435 to 445 °F for 7 to 9 hours
                              Yield stress = 165 MPa
                              Ultimate stress = 220 MPa
                              Fracture strain = 0.06
                              Don't heat the wheel over 300 degrees and you should be fine.
                              Don't buy an e30
                              They're stupid
                              1989 325is Raged on then sold.
                              1988 325 SETA 2DR Beaten to death, then parted.
                              1988 325 SETA 4DR Parted.
                              1990 325i Cabrio Daily'd, then stored 2 yrs ago.
