DIY Bent Wheel Repair ?
  • frankenbeemer
    • Sep 2009
    • 2260
    I also found this on the BBS site:http://www.bbsalloywheels.co.uk/manu...roduction.aspx
    Heat Treatment:
    The heat treatment phase, which lasts several hours, is in place to make sure that the material properties of the future wheel are exactly how they should be. The three-phase heat treating of the casting blank helps to improve the firmness of the aluminium alloy. Step one: solution annealing which takes place following the alloying stage in accordance with DIN 1706 and at temperatures of between 480 and 550 degrees Celsius. The temperature is selected so that a large enough amount of alloying elements are dissolved into the mixed crystals to increase the strength of the alloy. Step two: quenching. During the quenching phase, the casting is cooled down as quickly as possible to around 70 degrees Celsius so that it is ready for the next stage. Stage three: warm ageing. Warm ageing is in place to ensure that the material obtains the right strength. The process requires absolute precision. If, for example, the solution annealing is conducted at a temperature in excess of 550 degrees Celsius, the casting can no longer be used and has to be melted down.
    Don't buy an e30
    They're stupid
    1989 325is Raged on then sold.
    1988 325 SETA 2DR Beaten to death, then parted.
    1988 325 SETA 4DR Parted.
    1990 325i Cabrio Daily'd, then stored 2 yrs ago.
    • Simon S
      • Oct 2004
      • 3758
      Cool. Thanks guys. Very helpful information.
      Yeah - I have a high concern regarding use of heat. Liking the idea of a heat gun over a torch. I've been wanting to get a heat gun in my tool collection anyway..
      1 - Spin and check for signs of wobble. Mark trouble areas.
      if wobble is negligible and bends are localized to lip areas -
      2 - Warm areas with heat gun and reshape as possible.
      3 - Spin to double-check things out. Reshape as needed.
      4 - Strip any areas with curb rash and fill as appropriate with JB weld.
      5 - Straighten caps as appropriate for tighter installation (1-2 of caps I have fit ‘loose’)
      6 - Clean/scuff/prep wheels and caps for uniform finish and paint adhesion
      7 - Paint wheels and caps with wheel paint (Wurth or Duplicolor)
      8 - Install new roundel emblems to caps
      9 - Mount/balance tires on wheels with stick-on weights or lip weights on inside lip.
      10 - Avoid drifting into curbs at all costs.
      Oh god – I think I am going to be hating life while spending hours cleaning and scuffing out all that weave surface area on all four of those f’kers.
      P.S. George – you funny.
      -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
      • StereoInstaller1
        GAS
        • 22679
        I like the look of a nice set of weaves...but I will never ever own a set.
        GL, and post some pics as you fix those up.
        Closing SOON!
        Thanks for 10 years of fun!
        • Simon S
          • Oct 2004
          • 3758
          Oh – I will. All part of my Zen journey madness..
          • StereoInstaller1
            GAS
            • 22679
            Zen? What the heck you smokin'? Gonna share?
            Closing SOON!
            • ZekeTheSneak
              • 1562
              Google map, Wheel repair in your area.
              • Simon S
                • Oct 2004
                • 3758
                Well - it must be some good shit if I'm contemplating full-DIY refurbish on a set of gnarly-ass weaves..
                Believe me - I have. Basically, it's like:
                $560 + transport trips across Chicago to have a shop repair/refinish them
                OR
                $60 in paint + 20 hours(?) of my time
                I’m unemployed. Guess which route I’m leaning toward?
                If it's one thing I've learned about working on this car - is that the hardest roads are often the most satisfying when done..
                But we'll see - I need to check for bad wobble before I do anything.
                • jeffSDguy
                  • Feb 2011
                  • 386
                  Heat or flame, wood, and hammer should do the job. a metal heated will bend. unless if you use lava then it will evaporate. LOLOL
                  WTB E30. Right now $1500+ Vert or 4 door only.
                  Price range will increase every month.
