Looking at getting a set of rims that are 16x9 with +15 offset. They have 215/45 on them. Look a little meaty on the tires. I am running H&R cups and bilstein shocks.... and soon plan on doing drophats in the front. Will this work for me? Will I need any spacers to clear the strut housing? What about rolling the fenders? Help would be appreciated.
16x19 w/ 215/45?
16x19 w/ 215/45?
1989 Alpine 325is 2dr m50 swapped
Build Thread:
Current ongoing build. Check it out!
1991 318is 4dr rallycross
Rallycross Build Thread.
1991 Alpine 318is coupe - soldTags: None -
bump.sigpic
Build Thread:
1991 Alpine 318is coupe - sold -
I'm rebuilding my RS's to be 16x9 et12 and I'll be using 215/45 tires.
e30's currently in storage and won't be out for another month though, so I'll be sure to post here again when they're on.
I can tell you you'll definitely need a flat fender roll though on the rear, at least.
Originally posted by Jandersonyou can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.Comment
i have 225/45/16 on mine
i rolled my finders and do not rub under normal driving but pulling into my shop and hard turning i rub but im also going to pull my finders when my roller gets here :Dsigpic
^Back in the game^
BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
FS thread:
http://www.r3vlimited.com/board/showthread.php?t=214105Comment
from what ive read on other forums 16x9 +15 may be close to the inside strut, you may need to run a small spacer.
any tech type question to do with offsets etc i would ask in the stickied thread at the top of this forum. it is read and replied to by Mystikal and he is pretty knowledge on all this stuff...Comment
^Only in the front.
16x9 et12 is the closest you can get to the front struts without rubbing, therefore you'll need a 3mm spacer at least for your 16x9 et15.
The rear is a different story, but you'll want to make it as even as possible. That's usually done with 5-10mm more spacing in the rear.
