15X8 Kosei Project...Feedback Appreciated
  • A.J.
    • 95
    Just ordered a set of 15x8 Kosei K1 Race from the TireRack. They only had them in Miata fitment with a 54mm centerbore and -35mm offset. I've ordered a set of 12mm spacers and plan on having the centerbores machined out to fit the e30/spacers...
    Does anyone have any experience with having centerbores machined out? If so, any thoughts or advice would be appreciated. Also, anyone know a good shop in NorCal to have this done?
  • rThor432
    • Feb 2007
    • 3907
    It's a bummer that you can't just order these in direct fitment any more. Good luck.
    • Philo
      Ich esse kleine Kinder
      • 3334
      Any machine shop should be able to do the work.
      -tim
      Originally posted by Jordan
      I like the stance
      • FredK
        • 14763
        Is the centerbore custom to the Miata, or are they like other Koseis where hubcentric rings are used? I would think with 12mm spacers, you'd have enough room to just modify the spacer and not the wheel.
        • Philo
          • 3334
          Good point. You should be able to get a spacer made for the job.
          -tim
          I like the stance
          • A.J.
            • 95
            They're custom to the Miata for SCCA STR Class...TireRack confirmed they have a 54mm centerbore.
            • Ian F
              • 148
              There's a forum member here - RobE30? - who can make spacers to fit a Miata wheel to a E30 hub.
              '88 325is: Diamond Schwartz; 210K miles; Koni SA; H&R springs; poly bushings (sold)
              '03 TDi Wagon; 5 spd (Ho-hum DD; 326K miles and counting...)
              '64 Morris Mini Cooper (w/e vintage toy #1)
              '72 Triumph GT6 (w/e vintage toy #2)
              '73 Volvo 1800ES (future vintage restomod project)
              • A.J.
                • 95
                I already ordered the spacers and I'd rather have the centerbores bored out to 57.1mm than go with custom spacers. Also the custom spacer guys are getting a lot of flack here lately (THIS: http://www.r3vlimited.com/board/showthread.php?t=205760 )
                Is this really true? I spoke with a shop in Oakland that has a special machine to turn wheels on...but hey, I'm no expert on machining...
