e38 style 5 fundo vs bbs?
  • DuMa
    • 1101
    Does anyone know any major differences like weight or material wise? i know the sizes and design are consistent
    thanks
  • ak-
    • 12422
    BBS's are like a waffleswaffleswaffleswaffles hair lighter or something.
    In the ounce department, is what I've been told more than a few times. Personally I wouldn't care.
    1991 325iS turbo
    • Dj Buttchug
      • Jun 2010
      • 7671
      yea... no real difference at all
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • apextamer
        • 15
        Yeah I have both and can confirm they are almost identical. I am currently having them filled and drilled to 4x100. I should have back tomorrow. I will put the fundo and the bbs on a digital scale tomorrow ( with them both filled and drilled ) and give you weight specs on both. I would bet anything that they are the exact same mold. I have inspected these wheels thoroughly and can tell you the only visual difference is one says bbs and the other has fundo in the same location. I will update this thread with the specs I find hopefully tomorrow.
        • george graves
          • 19996
          Usually car companies have more than one manufacture of a part - that way they don't have all their eggs in one basket. I believe they have the wheels built to a specification.
          My guess is that fundo, will be every bit as good as bbs.
          Originally posted by Matt-B
          • grippymonkey
            • Jun 2011
            • 759
            I really like the Fundos personally... any of the spec differences between the two wouldn't be enough to care
            GRIPPY'S*GARAGE
            • apextamer
              • 15
              bbs with fill and redrill caps and valve stems - 18.7 lbs
              fundo with fill and redrill caps and valve stems - 18.9 lbs
              a difference of 3.2 oz
              • DuMa
                • 1101
                interesting. thanks for the info. i forgotten how much they had weighed in the first place as well
