Tire combo question
  • noahp45
    • Jun 2011
    • 107
    Tire combo question
    I just picked up a set of rims 16x8 XXR513. I want to know can I run 225/60R/16 on the back and 195/50/16 on the front with no issues?
    I have a 1987 325IC with stock suspension. I check the tire question section I saw that a intel-guy stated that no 16x8 w/o fender rolling however I also saw that e30 verts do not need fender rolling. So what's the deal? Thanks
  • L8 apexr
    • Dec 2010
    • 226
    Front tire size too small and the rear size WAY to big.
    • ttrousdell
      • Nov 2009
      • 1770
      hes right. 195 on 8" rims would be super stretched. I had 225/50 with my 16x8 on my stock suspension and I had to roll the fenders. Still had rubbing when i had my large friend in the car.
      The Build:
      • noahp45
        • Jun 2011
        • 107
        So what is the best size to run? For daily driver and looks good....
        I will lower later but that is another issue I will atack later.
        • e34john
          • Apr 2006
          • 3599
          225/45 you don't need to worry about the fenders because you will have at least a 4 inch gap between them and the tires.
          • noahp45
            • Jun 2011
            • 107
            So 225/50 would be to big? I ask because I can find 50 but 45 that's a mission.
            • MG325i
              • Jan 2007
              • 805
              225/50 in the back. depending on the offset of the wheels in front, 205/50/16 would be safe. or 205/50 all around.
              E30 325I > SOLD
              E30 318IS > SOLD
              E39 530I > SOLD
              EP3 > SOLD
              95 M3 > SOLD
              97 M3 > DD
              • Jaxx_
                • Dec 2009
                • 1880
                offset matters too bro, what are they? I have ET0 x8 wheels and they're not going to fit under factory fenders.
                • noahp45
                  • Jun 2011
                  • 107
                  0 offset
                  • Jaxx_
                    • Dec 2009
                    • 1880
                    Originally posted by noahp45
                    0 offset
                    time to get a baseball bat.
                    edit: I should say, you should be okay if you are not that low. mine have 205/50 and they stick out from the fenders a good 10mm. FWIW, this is a coupe, but still, I doubt that even with 'vert' fenders (whatever that entails) you would be able to clear those wheels. They'll poke.
                    • Cronopoulos
                      • Jul 2011
                      • 2187
                      Agreed, I have tons of room running (4) 225/40/16's
                      Rims - 16x8 +20
                      Project log -- DIRTY 30
                      2.7i * Megasquirt tuned * E85 powered
                      • MG325i
                        • Jan 2007
                        • 805
                        without some suspension its not going to look very good... stock already look like 4x4's... with small side wall its not very appealing unless your low. just my 2cents.
                        E30 325I > SOLD
                        E30 318IS > SOLD
                        E39 530I > SOLD
                        EP3 > SOLD
                        95 M3 > SOLD
                        97 M3 > DD
                        • noahp45
                          • Jun 2011
                          • 107
                          I agree the plan is to lower it, but I won't do that until I see a good deal.
                            • 37829
                            If you want to keep the correct overall diameter you should run a 205/50 or 225/45.
                            Classic BMW Specialists
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • E30_fiend
                              • Apr 2006
                              • 7348
                              Like matt said, stick with a stock overall diameter. You don't need a 225/anything in the rear. Your stock vert isn't going to have traction issues with a 205. Besides, the extra 20mm of tread isn't anything to be excited about.
                              Taylor
