bbs rm wheel fitment
  • egk2
    • 2426
    What would the correct offset be for an e30?
    I found a set with et20 front, et15 rear.
  • B2ThaZiZza
    • Aug 2004
    • 614
    I believe it is et20 but dont hold that to me, someone correct me if im wrong. et15 might need a 10mm spacer i think...
    • screamingbmwe30
      • Jan 2005
      • 415
      should be fine.
        • 34827
        using a 10mm spacer with a 15mm wheel would effectively give you a 5mm offset.. which obviously wouldn't work.
        • egk2
          • 2426
          My final offset for my 16x9's in the rear is 5mm, works out ok, what tire sizes do I run with these wheels?
          • Mystikal
            Wheel Fitment Expert
            • 9602
            Those are awesome specs.
            You can run 225/50/15 all around, you already rolled your fenders/quarters, right?
