16x9 rear spacer rubbing questions
  • GThomas
    • Dec 2010
    • 869
    Hey guys, want to get your opinions on what to do here. I have 16x9 et 10's in the rear and the outer lip of the rim is hitting the inner fender on full load. It hasn't done much to the wheels, except scrape off what looks to be the clear on them and make them flakey and dull on the lip, which I'm not thrilled about. Granted they're only esm reps, could I polish that outer lip back to life of would i have to strip all the clear and try to work in between the fake bolts?
    at this height they rubbed both a lot but i quickly raised it up after finding this out. Now i've been hitting the back roads for some spirited driving i'm finding the same is happening on hard cornering etc.
    Height now-
    Anyways, I swapped out my GC Springs in the rear for 700lb from my older setup which has around 400-500. This made it much better but the tire and outter lip still hit under full load. Should I add a spacer in the rear to avoid hitting the rim and only rub the tire on occasion? Thinking 8mm or 10mm spacer to make a final ET of 2 or 0. Also I'm on Falken 215/40's.
    Thanks!!
    1991 318is S52
    1987 325i Vert
    1991 325i
    2011 e70 X5
    Need Anything E30? -> http://www.gutenparts.com/
  • E30SPDFRK
    • 5715
    Roll your fenders more. That shouldn't hit at all if you have a good roll.
    Byron
    Leichtbau
    • MG325i
      • Jan 2007
      • 805
      have you rolled your fenders at all?
      E30 325I > SOLD
      E30 318IS > SOLD
      E39 530I > SOLD
      EP3 > SOLD
      95 M3 > SOLD
      97 M3 > DD
      • GThomas
        • Dec 2010
        • 869
        Fenders are rolled a bit, but I think they could go more. I suppose the best option would be to roll them out more, just worried about the paint...
        1991 318is S52
        1987 325i Vert
        1991 325i
        2011 e70 X5
        • mtlbloodshot
          • Jul 2011
          • 761
          roll fender or give some negative camber
          MY BUILD THREAD
          http://www.r3vlimited.com/board/showthread.php?t=235231
          INSTAGRAM : @luchcolaneri
          • jpichu
            • 266
            lower it morrrrrrrr ;-)
            Looks Good
            http://youtu.be/aOhYdZfY9QY
            https://vimeo.com/40801938
            • MG325i
              • Jan 2007
              • 805
              if you or know someone who roll's fender's well, you wont have to worry about the paint so much. thats the best way to go
              E30 325I > SOLD
              E30 318IS > SOLD
              E39 530I > SOLD
              EP3 > SOLD
              95 M3 > SOLD
              97 M3 > DD
              • GThomas
                • Dec 2010
                • 869
                Do you have to scrape out that inner bead that sits in between the inner fender and the inside lip?
                1991 318is S52
                1987 325i Vert
                1991 325i
                2011 e70 X5
                • FunfGan
                  • Jan 2011
                  • 4958
                  Thats odd... I have the same spring rate as you, basicly unrolled fenders and I barely ever rub my tires(it'd be impossible to hit the wheel), even on track.
                  Now that I looked, a spacer to only hit the tire would definitely be a good idea.
                  Go here be happy!
                  Ratchet Garage e30 V8 build.
                  • E30_fiend
                    • Apr 2006
                    • 7348
                    Im running et0 on an 8 with a 205/40 and I never rub tire or fender under full load. I have 5" 750lb rear springs with no adjusters. You need to roll the inner lip completely flat. You should have no problems at all running those wheels at that height.
                    Taylor
                      • 37833
                      A spacer will definitely NOT help your situation. Roll them more, you'll be fine.
                      Grover Beach, California
                      BimmerHeads.com
                      • GThomas
                        • Dec 2010
                        • 869
                        Thanks for the help guys, rolling the rears some more Sunday.
                        1991 318is S52
                        1987 325i Vert
                        1991 325i
                        2011 e70 X5
                        • CrusherCurtis
                          • 2532
                          I've read somewhere that you can't roll e30 rear fenders
                          • GThomas
                            • Dec 2010
                            • 869
                            You can, just had a buddy use the Eastwood to get my rears a little more. Worked really good :)
                            1991 318is S52
                            1987 325i Vert
                            1991 325i
                            2011 e70 X5
                            • FunfGan
                              • Jan 2011
                              • 4958
                              Cant wait to get my rears rolled out. I pretty much pulled/ rolled the fronts with my hands :pimp:
                              Go here be happy!
