16x9 rear spacer rubbing questions
Yes and no. Yes you can roll the fenders but no you can not roll late model rears flat. At least not with out some pre prep. What you need to do is chisel or wire wheel all the undercoat thats on the inside of the lip before you roll the fenders. Makes all the difference in the world. Also the late model inner fender has a little bump on it. You have to carefully tap it flat. If you tap to much or too hard you'll mess up the quarter panel. One of the benefits of an early model is now thick under coat or bump.
Tucking tire on an early model high arch car with 215/40's :)
www.gecoils.com
My euro 316 project Transaction FeedbackComment
Still hitting the rim
even after the additional fender rolling, guess i've got to raise it up a bit. Weird that no one else has had this problem..
1991 318is S52
1987 325i Vert
1991 325i
2011 e70 X5
Need Anything E30? -> http://www.gutenparts.com/Comment
1991 318is S52
1987 325i Vert
1991 325i
2011 e70 X5
