Hub spacer YES or NO?
  • DivineStyler
    • Jan 2010
    • 328
    I want a set of direct fit like a glove rims for the e30 but it seems somewhat difficult and I like the Konig remembers and even ESM, but hub size is 73.1...
    I kinda don't want to use hubrings... any oppinions?
    AutoX w/ a Roof Rack for extra Aerodynamics...
  • Vince30
    • 2318
    Whats wrong with hubrings?
    • straight6pwr
      • Sep 2004
      • 3450
      i would still consider a wheel that needs a hub ring a direct fit. its one more thing you need to buy, but they do not affect mounting like spacers or adapters do. in fact i was not even aware that my first set of Borbets on my e30 had hub rings, because they just stayed on the wheel when removing them.
      why are you concerned about hub rings?
      • DivineStyler
        • Jan 2010
        • 328
        i have a set of rims now with hubrings and they work fine I guess, but what about for the track? any concerns? I know how much vibration takes place without the rings takes place so wouldn't it be better to have the correct size in the first place? just wondering... all your oppinions are very well noted and helpful to my learning...
        • straight6pwr
          • Sep 2004
          • 3450
          no concerns. the hub (and hub rings) are meant to properly center the wheel. after that, its the lugs and friction between the hub and wheel that hold everything together.
          • bmwguy325is
            • May 2011
            • 1263
            I bought a lug conversion kit and forgo any hub rings.
            sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
            The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
            • Dj Buttchug
              • Jun 2010
              • 7688
              Stud kit... end of all issues
              Turbo M42 Build Thread :Here
              Ig:ryno_pzk
              I like the tuna here.
              Originally posted by lambo
              • DivineStyler
                • Jan 2010
                • 328
                I have a stud kit had vibrations with other wheels... if that's what you mean...
                if I had money sure... but that's a big price difference from a lug conversion to hub rings... if that's what you mean also? or refering to stud kit as well...
                • straight6pwr
                  • Sep 2004
                  • 3450
                  a stud kit wont center your wheels properly...
                  • GThomas
                    • Dec 2010
                    • 869
                    Aren't most of the ESM wheels 57.1 anyways?
                    1991 318is S52
                    1987 325i Vert
                    1991 325i
                    2011 e70 X5
                    Need Anything E30? -> http://www.gutenparts.com/
                    • DivineStyler
                      • Jan 2010
                      • 328
                      I don't think so... From what I see hub bore size is also 73.1
                      • GunMetalGrey
                        • Dec 2010
                        • 1499
                        No problems with Hub rings to report here, they are quite nice actually
