What offset???...............
  • g.ruff561
    • 1267
    I am looking at having some 16 inch wheels made up. I want to run 225 45 16 on all for corners. My current set up is 16x9, et 15 x 4 with 225 46 16. The fronts stick out a little too much. What would be my best option? I do not want to stretch. Just good solid fitment. I need info on offset to make this work. I f it could work. I do not want to use spacers if I can help it. Thats why I having the wheels made. Any suggestions? Thanks guys................G.
    • 37833
    A good example of perfect fitment is the Rota Slipstream. It's 16x8 ET20 and fits a 225/45 tire with just a average rear fender roll.
    Grover Beach, California
    BimmerHeads.com
    • g.ruff561
      • 1267
      Right now I'm running Schmidt Modernline 1pc, 16x9, et 15, 4x100 with center ring x 4. Are you saying et 20 would work? Would you recommend another size??? 16x7, et 15/20 up front with same tire size? By the way, thanks for your help.
      • Jaxx_
        • Dec 2009
        • 1880
        well, however far they stick out you know what offset you should run with a x9.
        I would run about +25 but it depends on how aggressive you want to go.
        • g.ruff561
          • 1267
          I just want a good clean front end look using the 225/45/16 tire with no rub and no fender roll. No spacer. 16x7 , et 15, 20, 25??? What say yee?? Again thanks for your response.
          • E30_fiend
            • Apr 2006
            • 7348
            You won't be able to run any higher offset in a 16x9 without hitting your strut tube. A 16x8 et15 or 10 qulouks look dope and fit well.
            Taylor
            • Cronopoulos
              • Jul 2011
              • 2187
              Taylor
              This
              Project log -- DIRTY 30
              2.7i * Megasquirt tuned * E85 powered
              • g.ruff561
                • 1267
                Thanks. What about 16x7, et 10 or 15, running on 225/45/16. Or 16x8, et 10 or 15. Same tire. Thanks again.......................Be blessed.
