well 255's on the 9's will be perfect idk about the offset im 5lug and am running 255 on stock 8.5 contours, with no rubbing.
Flush Fitment (STANCE) Thread
sweet. That's good info :) what are you running on the fronts?Just a little project im working on
- http://www.lse30.com -
Yeah, I was kind thinking of giving the 255's a run all round :oJust a little project im working on
thats going to be hard i just put a 245/35/r17 up front and it fits with my 12mm spacer but would rub a little on the fender, might work with like a 7mm spacer. 255's would prob not going to work, and i have a custom set of BC coils with small perch's and it would be an extremely tight squeeze. You might not be able to turn with 255's
Also have BC's and the guards arent a problem :)Just a little project im working on
Wheels/spacers:
Artec MI 3pc 17x8/9 4x100 et38(before spacers)
42 Draft Designs custom spacers:
25mm front 15mm rear.
Tires:
BFG G-Force sports 215/45/17 235/40/17.
Suspension:
-GC coils 700r/500f
-GC e28 race camber plates
-GC Rear race shock mounts
-GC E30 M3 custom sway links
-Koni valved adjustable shocks and struts
-Shortened housings and E30 M3 tabs~by me
-Meyle arms
-Tree house racing eyeballs
-AKG bushings/IE replacing ALL stock
-e30tech weld in correction kit
-UUC 22mm SwayBarbarian front kit.
-Condor Speed engine and transmission poly bushings.
Instagram: @BWeissLeather
Current cars:
~ '87 325 M30B35 swap
~ '87 535
~ 01 540 Msport 6spd
~ '06 X5 4.8is
Originally posted by White325is View PostNo idea. I was on bags. So the rear sat as is when laid out and the front I made camber plates to adjust it to where I wanted it. But never had it on a rack. It was a shit load tho.
Sorry for the odd picture.
