XXR 16x8 et20 all around
  • jaywood
    • Jul 2010
    • 4528
    Got any more pics of that^^^?
    • Cronopoulos
      • Jul 2011
      • 2187
      For every set of XXR rims I have owned, I have not purchased tuner lugs. The stock lugs work fine, you just need a thin walled socket.
      Like everyone has said +20 on an 8" wheel w/ rolled fenders seems to be the happy medium for perfect fitment (in my eyes). Here are 16x8 +20 w/ 225/40/16 (rolled fenders & pre-face-lift arches)
      Project log -- DIRTY 30
      2.7i * Megasquirt tuned * E85 powered
      • jaywood
        • Jul 2010
        • 4528
        So the stock lugs will work fine?
        IRUNEDM got me thinking about et20 up front and et0 in the rear....
        • Cronopoulos
          • Jul 2011
          • 2187
          Yes sir, I used the stock lug nuts and they worked fine. Thin wall 17mm is a must though ;)
          • jaywood
            • Jul 2010
            • 4528
            I see you got a tuner stud kit, I saw your review!
            I was thinking about getting some of those as well....
            • IRUNEDM
              • Oct 2009
              • 1122
              I will try to get more pics tomorrow for ya. I like the rear with the 20mm spacer because I can rotate my tires without having to get the tires unmounted/mounted/balanced.
              Feedback
              Instagram - @e30_mtech2
              • Cronopoulos
                • Jul 2011
                • 2187
                Yeah both of them work great!
                • ak-
                  • 12422
                  1991 325iS turbo
                    • 37833
                    Those are a size too tall though. 225/45 could be correct.
                    Grover Beach, California
                    BimmerHeads.com
                    • drummerchubbs
                      • 512
                      I'm getting the XXR 531 16x8 et0 all around. Last time I had xxr 15x8 et0, my wheel flew off at 30mph in the middle of the night on the stock lug bolts. After examination, they were only fastening on 3 threads. :( I'm going for muteki sr48 open ended version.
                      SEE THE MOST BORING M50NV BUILD THREAD HERE: http://www.r3vlimited.com/board/showthread.php?t=288275
                      • StreetMafia21
                        • Sep 2011
                        • 250
                        im picking up a set of xxr 531 offset +20, what tire profile will i need to run if i wanna be flush
                        • PNWDan
                          • Feb 2011
                          • 1326
                          205's
                          profile is the side wall height as a percentage of the width. The first number is the width in millimeters. Smaller width on a wider wheel = more stretch.
                          1987 Alpinweiß 325is
                          Like the PNW E30 Local Crew Facebook page
                          • StreetMafia21
                            • Sep 2011
                            • 250
                            fosho thanx ima prob run 205 45 16 with +20 offset
                            • B-well
                              • 1042
                              i have 501s at 16x8+15F and +5R with 245/45 with no problems on sports with rolled fenders
                              if youre into a sport type spring with minimal fender rolling, i would recommend 225/45
                              thats such a little tire. if you plan to lower your car at all get yourself some kind of oil pan protection
