just a quick fitment ?
  • mrsleeve
    • Mar 2005
    • 16390
    OK so the project begins in the next week or 2 depending on when the eyeball arms show up. Basicly I am redoing the entire suspension and brakes on my car (88 325is) Cup kit, control arms, bushings, pads and rotors, strut berings, shock mounts and what not. Everything but sway bars those will wait till spring.
    Now my wheels are 15x7 et 26. I want to fit 225\50\15 g-force sports.
    All that is need may be a bit of fender rolling up front right? Any one tried this set up yet?
    I did a search came up with a little info, I just want to be shure it will work before I spend 400+ on tires.
    as usual thanks for help.
    RJ
    Originally posted by Fusion
    William Pitt-
  • Digitalwave
    is a poseur
    • 6300
    With ET26 I'd be more concerned with rubbing on the strut rather than fender rubbing.
    RISING EDGE
    • Brew
      • 3060
      You should be good. I'm running 225/50-15 G-Force Sports on 15x7 et25 wheels with ZERO rubbing and I'm pretty low. If you are going to rub anywhere, its the rear fenders.
      '91 318is
      • mrsleeve
        • Mar 2005
        • 16390
        thanks guys, that is what I was hopeing to hear.
        William Pitt-
