fill and redrill
  • down_shift13
    • 44
    fill and redrill
    Hi everyone, I'm located near torrance and i was wondering if any of you guys know a good reasonably priced place to fill and redrill wheels?
    I did a search and read about LAX wheels, but most responses said that they are not consistent with the hub centers and they now charge extra. Any ideas?
  • ZekeTheSneak
    • 1562
    vrwheels.com has a shop that redrills for them. shoot them an email.
    • cactusjacks1
      • Sep 2004
      • 1216
      fill & drill
      As a newb, you need to read the FAQ's & learn to use the SEARCH function. A one second search "fill & drill" turned up over 100 threads. Having said all that, this company is highly recommended, but a little bit of a drive - -
      Inland Wheel Center
      640 W. Mill St.
      San Bernardino 909-514-0091
      See Lenny (owner)
      $220 - $250 for a set of 4 - waffleswaffleswaffles's a complete fill & then mills off the top of the weld so it's even with the center face top, & mills back of face as well. Price varies a little depending on 1 or 2 piece - open or covered lugs & if you want tuner (smaller "drill") or regular lugs (larger "drill").
      Picture is similar to the quality of their work (used in another post)- nothing but great comments on price, quality of work, craftsmanship & fast turn around - they've been in business over 25 years & it shows. Well worth the drive from Torrance !! (hope the OP doesn't mind me using his pic - note this is the larger "drill" for OEM stud bolts). PM me for more info.
      [I
      • Robotin
        • Jun 2011
        • 4471
        definetly gonna remember that cactus....
        OP, ur in the torrance area?? im often in the torrance area with some of my e30/e28 friends.. hope to see u around!
        1989 325i SETA stroker [delphin] R3V'd 8/31/2011
        1989 325ix [zinnoberrot] $OLD
        1970 2002 [Nevada]
        Originally posted by Herr Faust Schinken
        guy must have slid into something that doesn't look like a car vs car hit
        Originally posted by ak-
        Must of slid into Rob
        • einstein57
          • Jun 2007
          • 10780
          I guess they stepped their game up. These were done in November of 2011
          Here you go, pics of the fill/redrill which was done by professionally by Inland Wheel Center in San Bernardino, CA
          www.gecoils.com
          • cactusjacks1
            • Sep 2004
            • 1216
            This is a good example of ordering the "economy" fill & drill. Structurally it is as strong as the one I pictured in the post above. The difference between the two is purely cosmetic. Note this version also has the tuner lugs (smaller diameter hole for the lug) & that their hole doesn't encroach as much on the center bore. This is one of their options available on the menu of "fill & drill" accounting for the cost range mentioned in my post above.
            [I
