XXR, CCW knockoffs
Car looks great man!
That's pretty close, make sure any stick on weights aren't going to hit the calipers.Lof8 - I printed and cut out your Massive Brakes template. Its a fit! a very CLOSE fit, but its a fit.
I've added a yellow line to show the contour of the wheel. Theres about 3/16" clearance at the closest point. I DID insert the hubcentric spacer into the wheel before I test-fit the template, and had laminated the template on a piece of cardboard to keep it rigid.
Really interested to see if the UUC big brake kit will clear the 15x8" +20 so if anyone has the 15's could you please try this out for me. would help so much
I wasn't aware that 15lbs was lighter than 13. That must be why i'm struggling with physics.
http://www.nlmotoring.com/XXR-531-wh...p/53158080.htm
http://www.tirerack.com/wheels/Wheel...9&autoModClar=Comment
