Widest tires for E30?
  • apostate
    • Feb 2012
    • 148
    Hi all,
    What are the widest tires that can fit a normal E30 without any interventions on the flares?
    Is it possible to fit 235/../17 front and 255/../17 rear? What wheels would they need, J and ET?
    Thanks!
  • FunfGan
    • Jan 2011
    • 4958
    No way those are going to happen haha. 224, maybe 235 all around.
    Go here be happy!
    Ratchet Garage e30 V8 build.
      • 37829
      I have 235/40/27 all around on one of my cars. I would say 235 is about max for the front but I've seen a couple people do 255 rear. This is assuming you roll your fenders nicely all around.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • E30 331is
        • Sep 2011
        • 1166
        Youd have to roll them fenders nice to get 27" on. Donk donk donk e30!!
        • u3b3rg33k
          • Jan 2010
          • 2452
          Pretty sure 225/50/15s work on stock fenders.
          Ich gehöre nicht zur Baader-Meinhof Gruppe
          Originally posted by Top Gear
          Just imagine waking up and remembering you're Mexican.
          Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
          • B-well
            • 1042
            my cabrio has stock fenders and 245/45r16
            front wheel is slightly turned, fronts and rears are both the same "flushness"
            • shiboujin
              • Feb 2006
              • 2791
              255s are max for the rear. 225 is the widest I've fit on the front
              • Alberthype
                • May 2011
                • 132
                I have 225 all around. And i'm lowered on springs. I do rub but thats because I don't have spacers
                • u3b3rg33k
                  • Jan 2010
                  • 2452
                  You might want to head over to this thread http://www.r3vlimited.com/board/showthread.php?t=83125 if you have a specific question.
                  • apostate
                    • Feb 2012
                    • 148
                    Anyone with 235/40(45)/17 front and 255/40/17 rear?
                    And on what wheels, J and ET?
                    • einstein57
                      • Jun 2007
                      • 10780
                      I've run 245s all the way around but you have to have the fronts on full camber (camber plates).
                      www.gecoils.com
                      • Cliche Guevara
                        • 672
                        I'm running 225-45-17 all the way around without rolling my fenders and I'm gonna try for 235-40-17 with my next set of tires.
                          • 34839
                          235-245 should really be no problem, on all 4 corners - assuming proper suspension setup and fender lip rolling, along with careful choices of offsets and wheel widths.
                          basically, if you want to be scraping the ground in a dumped car, 10" wide rims poking out with a negative offset - you aren't going to be able to fit wide rubber, unless you think a 205 is wide.
                          235s on all 4, and they're R-dots - a comparable street tire would be narrower. a 245 street tire would be about the same width (aspect ratio will complicate things of course).
                          • trackjunkie21
                            • Jan 2010
                            • 3962
                            235's are very possible all around, I have 225/50/15 right now and they fit fine with a bunch more room left.
                            Originally posted by Wh33lhop
                            VANOS: sometimes you just need to go full retard.
                              • 37829
                              Uhhhhh...?
                              Grover Beach, CA
                              www.BimmerHeads.com
