15 x 7.5 et28
  • Eurospec
    • 2613
    15 x 7.5 et28
    What should I expect with 225/50 Ziex tires? Would someone enlighten me as to how stanken offset operates
    • 37834
    I'm pretty sure the tires would rub on the strut.
    Might need a 5mm spacer
    Grover Beach, California
    BimmerHeads.com
    • 2002maniac
      • 4260
      I'm betting 10mm
      • Digitalwave
        is a poseur
        • 6300
        Originally posted by 2002maniac
        I'm betting 10mm
        No way, he'd rub his fenders with 225's and ET18.
        RISING EDGE
        • Mystikal
          Wheel Fitment Expert
          • 9602
          3mm spacers on the front, worst case scenario. You can use the stock lugs for those, the spacers themselves shouldn't cost more than $20.
          But honestly try it first. You just might make it.
          • Jarvis
            • 2132
            On ET35 16x7.5" wheels with 225/45's and 8mm spacers (so a collective ET27 offset) I had maybe 1.5-2mm clearence to the struts. At full lock I'd rub the plastic inner fender, but they technically fit.
            Like stated above, something between 3-5mm would probably be perfect for you.
            • 2002maniac
              • 4260
              I doubt it. My 15x7's are et17 and no rubbing with 225's
              -2.5 degrees camber helps
              • Mystikal
                • 9602
                Also just so you guys know, the ZE-512's he has run narrow, much narrower than BFGs or Toyos.
                • Eurospec
                  • 2613
                  Anyone care to explain how offset and fitment coalesce?
                  • decay
                    • 5637
                    this should help clarify it for you. play around w/ it for a little while and you'll get the idea.
                    http://marksink.com/tire_wheel_offset/offset.html
                    stock b-weaves are 6.5 et30.
                    past:
                    1989 325is (learner shitbox)
                    1986 325e (turbo dorito)
                    1991 318ic (5-lug ITB)
                    1985 323i baur
                    current:
                    • IS
                      • Jul 2005
                      • 366
                      It probably wont rub - there is approximately 5-6mm of clearance between the rim and strut for that offset and rim width. The tread width on those tires is 7.7" (compared to the 7.4" I'm currently running and only part of the rim protector on the tire sticks past the wheel).
                      Yes, it'll be tight, but I'm almost positive it wont rub on the strut.
                      87 325IS - Delphin Grey/Cardinal
