16x8 bbs mahle questions?
  • mr.vang
    • 4371
    so im about to pull the trigger on a set of 16x8 bbs mahle for $120 but the bolt pattern is 5x112. i believe the offset is 20. will this be crazy poke with 4x100-5x112 adapter? fill and drill is not an option.
  • Dj Buttchug
    • Jun 2010
    • 7685
    probably. any 4 to 5 lug adapter comes in 18mm at the thinnest. thatll put you at an et of +2... most would consider that offset to low although i ran et0 all around and it didnt poke
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • mr.vang
      • 4371
      pretty decent condition, not bad for $120. what tire size are you running on your 002 Dj?
