Q: 16x7 ET40 requires 15mm spacer, correct?
  • bmwsmurf
    • 509
    Hey guys,
    Been searching through old threads for offset/spacer info and I just wanted to confirm:
    If I get a set of 4x100 16x7 wheels with 195/50 tires, ET40 , I'll still need a set of 15mm hubcentric spacers correct? If I mount them without spacers, they will probably look really weird and might rub against the front strut, right?
    Damn spacers will cost $120 though, don't want to get the wrong ones.
    Also, aren't these tires a little skinny for 7" wheels?
    Thanks.
    Visit the 3 series heritage site (work in progress):
    http://www.creativesmurf.com
  • Brew
    • 3060
    15mm spacers would be about ideal for that wheel size, although you could go with 20mm also. The best tire size would be 205/50, but you could also squeeze 225/45 on there.
    '91 318is
    • Digitalwave
      is a poseur
      • 6300
      That's a bogus tire size. I would personally run 20mm spacers... oh wait I am. But 15mm would work too. Spacers are closer to $200 for hubcentric H&R spacers, then you also need to buy longer bolts or a stud kit.
      RISING EDGE
