17x10s Pics with specs
There are plenty of e30s with 255/40/17s that don't look stretched. Thats only 10mm on each side from the ideal sized tire. I'm just afraid i won't have any grip in 1-3rd with anything less then a 275.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
teaser bump
www.gecoils.com
95 7.1L 16V E36 M3
Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
LIKE my Facebook Page! CLICK HERE
Can anyone point me to someone with 4x100 17x10" Brock B1 wheels? If willing to sell, I want them.
john.s.khalil@gmail.com
Text or call: 908.421.1023
Thanks!Comment
gonna bump this up..
for those running a 17x10 et15..with 235/40 or 245/40 tire, what type of fenderwork was done?
I'm currently running 16x8 with 0 ET...allready have my fenders pulled and rolled to the max...
I'm about to pull the trigger on some 17x10's and am wondering if my fender will be okay as-is.
car is '90 vert.Originally posted by flyboyxi have watched my dog lick himself off a few timesComment
245s dont look too bad on the 10 inch wheel. but someone should post theirs on 265/275 :DOriginally posted by blunttechr3v does not fuck around. First you get banned, then they shoot youComment
I'm about to attemp to fit 255/40/17 on the rear, on 17x10 et20. I will keep you guy updated.
I'm just waiting on my spacers for the front...that will be on 235/40/17 on 17x8.5 final offset et20.E30 now S52
2008 Suburban LTZ (Family and TT hauler)
325xiT (Sold)
sigpicComment
back up with this...
searched, and getting lots of confliciting feedback.
who ACTUALLY has a 17x10 et14 rear setup and is running a 245/35/17 tire?
how much of a roll (if any at all) was required?
those running a 225/35/17 still needed a roll?
application is a 90 vert lowered 1".
i'm being told i need a perfect roll and incredibly stiff springs, whereas many guys here don't seem to sport these specs..Originally posted by flyboyxi have watched my dog lick himself off a few timesComment
I rolled, a lot I think, and cut a bit on the inner sheet metal of the fender and 255/40 doesn't fit at all! I tried 235/40 and I still have a bit of rubbing... I will see what I can do... I will try to cut more sheet metal inside the fender. Note that I'm doing my test fit with Toyo RA1, a tire that run pretty large, like 9'' vs 8,5'' (bidgestone RE-11) for a normal tire (data from tire rack)
I'm low (60mm drop) with soft spring... around 300lb/in on the rear. Should replace spring.E30 now S52
325xiT (Sold)
sigpicComment
with a 225/35 that runs small ( for example Falken 452 etc ) and an offset of 14 you need to roll the lip totally flat, pull as much as is possible on the lip and then shave the lip out ( in that order ). you will still have minor issues on bigger bumps and driveways.
If you decide to run a good degree of camber you'll be good.
I have a little experience fitting extreme sizes to cars ;)PBMW Magazine. PVW Mag
Fender Rolling for dirt cheap in SoCal.
Hit me up.
Check out my work...
http://www.r3vlimited.com/board/showthread.php?t=165114
