double checking before i buy
  • phucking-low
    • 32
    These are excatly what im looking for, there staggered fit 16x7 front 16x8 rear, but there zero offset. My car is a 91 318is lowered on H&R springs not real low. Will these fit being zero off set and the width i stated above, if so im going to order today its time for some wheels lol. And thanks for your help.
    http://www.ebay.com/itm/16-16x7-16x8...72ea42&vxp=mtr
  • Mr. Tasty
    • Jul 2011
    • 3421
    never mentioned tires
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • phucking-low
      • 32
      That's what I was wanting to know, if there was a tire that would fit these wheels with there offset that will not rub
      • Blackout
        • Apr 2011
        • 4130
        Gotta be real low to justify the zero offset otherwise you are asking for a 4x4 hip stance.
        I hope that you are on H&R Races, at least. Sports are not going to cut it.
        Example below of how they might look without a proper drop. And what tire size ? Need a pic of your car to determine that..
        » PARTS FOR SALE
        » TRANSACTION FEEDBACK
        • 325ix
          • Aug 2009
          • 7783
          It will look funny with the super low offset and mild drop. You pretty much need coilovers to pull off the et 0. I would look for 20-25mm offsets.
          • phucking-low
            • 32
            My H&R's are a grey not sure if there sports or race
            • phucking-low
              • 32
              Ok did some searching and I have sports, so I will be getting coil overs so what size tire 16x7 front 16x8 rear should I get then?
              • AE86
                • 272
                I think grey is O.E. Sport Spring, which is slighty different then Sport Spring which is a dark blue. Here's an application guide that might help you out.
                WTB: Diamond Schwartz Hood
                • phucking-low
                  • 32
                  what size tires are on this e30?
                  • mr ilia
                    • May 2011
                    • 582
                    Size: 2 rims are 16x7 with 2.5" Lip, offset is +15
                    Size: 2 rims are 16X8 with 3.5" Lip 0ffset is +0
                    Bolt Pattern: 4X100 and 4X114.3 (4.5")
                    Offset: +0 mm
                    I pasted this from the seller's description. It seems the fronts have +15 offset, and with 7 in wide rim you should be able to clear with the standard size tire. You may require fender roll...depending on the tire model.
                    I'm not sure about the rears, but I' would imagine, without any stretch on the tire, you're looking to do fender roll at the very least...
                    • phucking-low
                      • 32
                      well again, if i was to have to get a streched rear tire what size would that have to be?
                      • phucking-low
                        • 32
                        from my research it looks like 205/40/16 in the rear this sound correct?
                        • Kershaw
                          • 11822
                          grey h&rs are the oem sport replacement. the least drop of all.
                          AWD > RWD
                          • Blackout
                            • Apr 2011
                            • 4130
                            205/55/16 all around. And if go you low on coil-overs than 205/40/16 is a great candidate for your car.
                            » PARTS FOR SALE
                            • mr ilia
                              • May 2011
                              • 582
                              205/55/16 is not proper size.
