Vote. 17x9's or not?
  • 2002maniac
    • 4260
    17x9 w/245's. Think they look too ricey? I kind of like them.
    on this car
  • Dave
    E30 RAT
    • 11675
    Them's Beefy tires - how are you going to make them fit?
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
    • DaN
      • 1265
      I think they are way too wide for an e30.
      • bimmer8604
        • 3017
        what size tires will you run? I'm having problems just finding some simple 225s for my 16x7.5s.
        Kyle
        1988 M3, 97 840, 99 XJ
        DILLIGAF
        • Jordan
          • 12912
          17x8.5 with 245's fit fine on my car.
          I also have higher rear arches and a completely different suspension.
          4x100 17x9's with 245's aren't going to work on your car without serious fender modifications.
          https://mtechniqueabs.com/
          • 2002maniac
            • 4260
            I have some added clearance due to the 2.5" springs and negative camber. I'm thinking of ordering one wheel to make sure, but I think it will fit.
            Several tires are available in 245/35/17
            • Jordan
              • 12912
              What offset at those wheels in 17x9
              If I know that, its pretty easy to say if it will fit or not.
              • 2002maniac
                • 4260
                20mm. I think a small spacer will be needed in the front. I will turn a spacer that leaves as little clearance as possible.
                • Jordan
                  • 12912
                  17x9 ET20 will stick out past the fender front and rear.
                  Spacers will only make it worse.
                  Not sure about inside (strut housing/rear shock/inner fender well) clearance.
                  • Nick325is
                    • 1409
                    17x9 is probably going to rub on the front strut if I remember correctly. Wasn't Alex running a 5mm spacer with the brocks to make them 15mm?
                    Nick
                    • 2002maniac
                      • 4260
                      hmm, I was thinking that I would have clearance problems with the strut before anything else.
                      Calling Mystical!! :)
                      • T.Dot E30
                        • Mar 2004
                        • 536
                        He's at school, we got maddd midterms and assignments around this time of year.
                        He'll chime in soon.
                        • Mystikal
                          Wheel Fitment Expert
                          • 9602
                          Reporting to work.
                          17x9's will require ET12 or so at the highest, so you're looking at 8-10mm spacers and about 1.5" of wheel sticking out the fenders.
                          Whether or not that looks good is up to you. It's excessive width for a car that's not in competition, though. Stick to your 17x8" ET20 idea, those will fit and provide more than enough traction.
                          • 2002maniac
                            • 4260
                            yeah, I just think the Pro-race wheels are uglier than sin. :(
                            • Mystikal
                              • 9602
                              Form < Function
                              I hate my current 16's. But I'll be damned if they weren't cheap and hold 225's without rubbing, sans spacers.
