Bad tires or rims?
  • 09june29
    • Apr 2012
    • 38
    Hmm so if I jack it up n shake it if it has play its the hubs?
    • 09june29
      • Apr 2012
      • 38
      Then if it don't it's the rims or tires?
      • 09june29
        • Apr 2012
        • 38
        Ok I'll check this out tomorrow thanks guys I'll let you know what I find out
        • Vegas227
          • 214
          I had the same issue. My tire blew when I was going 110 mph... Change out the tire now... Might be a different issue for you but thats what mine was doing.
          Basaltblau 318i (Sold) Dammit do I miss these cars... Someone sell me one!
          2011 VW GTI 6 speed
          • 09june29
            • Apr 2012
            • 38
            My buddy has basket weaves for sale 225$ for 5 is that a good deal
            • gearheadE30
              • Jun 2007
              • 3734
              did you check and make sure that the rims are actually the problem? If you've only got a g to your name, you sure as hell should take the advice that's been given and figure out what the problem is.
              Project M42 Turbo
              • 09june29
                • Apr 2012
                • 38
                Well I put my back rims on my front and still has the noise and vibration now is it the hubs?
                  While it is possible for the wheels to get bent and rotate out of round, the chances of that are pretty low. The out of round that you see when you spin the wheel is much more likely to be out of round tires. Which would go a long way towards explaining the noise and vibration.
                  However, if non-hubcentric wheels are being used, the odds of the rims running true is pretty low and they could be the cause of the out of round condition.
                  Take the car to a good tire shop and have them check out the wheels/tires.
                  • 09june29
                    • Apr 2012
                    • 38
                    Thnx that's what I'm thinking ima have to do
                      Good plan. Having a pro diagnose the issue will be cheaper in the long run.
                      • 09june29
                        • Apr 2012
                        • 38
                        Yea just unemployed at tHe moment so money is tight
                        • F34R
                          sLaughter
                          • 12376
                          Bad belt in the tire, see any bulges on the sidewall? And like the others said: jack it and see if you have any play in the hub.
                          Instagram: @BWeissLeather
                          Current cars:
                          ~ '87 325 M30B35 swap
                          ~ '87 535
                          ~ 01 540 Msport 6spd
                          ~ '06 X5 4.8is
                          • 09june29
                            • Apr 2012
                            • 38
                            Don't see any bulges in the tire
