Lets talk tires.....
    So I am due for a new set of tires. I have 16x8 rota slipstreams. I am looking for a 225/45-16 or a 225/50-16. My fender are rolled pretty hard so i can fit whatever i need to. Car currently has 225-45-16 Yokohama AVS ES100(280 AA A - 22lbs). They are pretty good in the dry, but a bit slippery, and pathetic in the wet.
    The candidates fall into two primary categories. Ultra high performance vs regular high performance. Basically a UTQG rating of 140-160 vs a rating of 280-300.
    All prices and tech spec from tirerack.com
    all the tires are about 25lbs each and about 10/32" starting tread.
    Super awesome high performance category:
    Dunlop Direzza Sport Z1 "Star Spec"
    225-50-16. UTQG rating: 200 A A. Price $138 per. Made in Japan
    I have heard a lot of good stuff about these tires, but they are pricy.
    Hankook RS-3
    225-50-16 UTQG rating: 140 A A. Price $119 per. Made in Korea
    I have also heard good stuff about these. My e30 was made for the track even if it doesnt find its way there that often, but I do a lot of miles, and I need the tires to be worth a damn in the wet.
    Slightly lower performance category:
    Hankook Ventus V12 Evo K110
    225-50-16 UTQG rating: 280 AA A Price:$89 per. Made in Korea
    These seem like a good all around tire, but I dont have any personal experience with it.
    Dunlop Direzza DZ101
    225-50-16 UTQG rating: 300 A A Price:$94 per. Made in Japan
    these have kinda crappy ratings on tirerack.com but again I dont have any experience.
    Yokohama S.Drives
    225-50-16 UTQG rating: 300 AA A Price:$100 per. Made in Japan
    Basically the same tire as I have right now.
    thoughts?
    CHEAP REBUILT INJECTORS
    Need Quality Brakes? BimmerBrakes has it!
    For anything Else go with BluntTech!
    Hankooks are the best tires in the dry by far, and they're not deadly in the rain like a Kumho Ecsta XS. The DZ101 Star Spec is a great tire, but it does lose out to the hankooks in the dry, but it's going to wear a bit slower and definitely be safer in the wet.
      All this info is covered in the tire/wheel section. fail
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
        I typically buy the cheapest tires available.
        I Timothy 2:1-2
          I don't understand why the DZ101's have a bad rating on Tirerack. I realize they aren't at the same level as the starspecs and the RS3's but they have been good overall for me. I had to run them at the track a couple times and was pretty impressed for a little bit harder street tire. I would take them over the S-Drives any day. I'm on my second set and will probably continue to buy them as street tires for a while.
            This tire will see more time on the street than on the track. And here in texas it can be nice and clear one minute and then torrential flood from hell the next. So of the top grip tires the nod goes to the Star spec.
            your post is not useful. fail.
            on a stock car, that can be ok. On this car that will not cut it.
            They have really poor ratings in the customer section. People leave them poor reviews - thye are supposedly bad in the wet, wear quickly, and dont offer good traction for the money.
              You left off the Conti DW, which is at least as good as every tire you did list.
              Originally posted by kronus
                Thats because they dont make it in the right size.....
                  I direct linked the second of your two specs...?
                    225/50/16s are gigantic - about an inch taller than stock, just FYI.
                    8380 Laboratories
                    M3 Champs Poster
                      BFG G-Sport Comp2
                      My e30 with 225/50/16 on rotas 16x8
                      Current cars:
                      ~ '87 535
                      ~ '06 X5 4.8is
                        True. He did post specific sizes though!
                        I used this when calculating what size to put on my RGPs:
                          This. OP - you sure you aren't talking 225/50/15?
                            Anyone have the Toyo Proxes R1R? New on Tirerack and 225/45/16.
                            1991 318is S52
                            1987 325i Vert
                            1991 325i
                            2011 e70 X5
                            Need Anything E30? -> http://www.gutenparts.com/
                              Sorry I herped, and clicked on "other sizes" However what makes these tires any better than the evo v12s? the ratings on tire rack are about the same...
                              yes. I understand this.
                              BFG G-Sport Comp2
                              wear rating is a bit higher than I want, again what distinctuates these tires from the evo v12s? or star specs?
                              http://www.rimsntires.com/specs.jsp
                              Thats a handy link. Thanks!
                              yes.
