How Does Tire Sizing Work? READ THIS
This is a sticky topic.
    • 37834
    • Tire
      • Tires only have one shape, but they have many sizes. The size (along with other pertinent information) is stamped on the sidewall of the tire. It has three measurements of the tire and the numbers are separated by forward slashes. Use the following tire size as an example to break down the definition of the size of the tire. 185/65/R15. The numbers and letters after this number define the speed and load ratings of the tire.
    • Tire Width
      • The width of the example tire is 185 millimeters. This measurement is measured with the tire mounted and inflated to specifications from the widest point of the sidewall to the widest point of the opposite sidewall; straight across. The higher the number, the wider the tire. The lower the number, the narrower the tire.
    • Aspect Ratio
      • Also known as the section height of the tire, this measurement is used to determine in a percentage, and measures the sidewall from the wheel to the tread. In the case of the example tire, the aspect ratio or height of the tire is 65 percent of the section width of the tire. The higher the aspect ratio number, the taller the tire. The lower the number, the shorter the tire.
    • Diameter
      • The last number on the example tire size is the diameter of the tire. In this case, 15. The "R" before the number indicates it is radial ply. This is the most common letter you will see there for car tires. The number after the letter "R" is the measurement of the size of the hole in the middle of the tire, and determines what size rim or wheel to mount the tire on in inches. While some heavy duty trucks may use 1/2 inch size (like 16.5) most all cars only use inches. The example tire size has a diameter of 15 inches, and will only work on a 15 inch wheel.
    • Tire Size Conversions
      • There may be other sizes you can deviate from for your vehicle. Often, this information will be offered on the tire label. For example, if your car took the specific tire size used in the example size, it may also display another number at the bottom of the label in a 16 inch rim. The rim and tire for each wheel would have to be changed, but the information would provide you with another option that would fit the wheel well of the car without interfering with the suspension or chassis components of the car. Also, most reputable tire dealers will have a tire size conversion chart where the actual tire size of your car can be compared to similar sizes from which you may want to deviate. For example, you may wish to go with a wider tire or a taller sidewall tire. This size conversion chart would show in inches and/or millimeters how much difference there is between the actual size and the size you desire.
    Grover Beach, California
    BimmerHeads.com
  • FunfGan
    • Jan 2011
    • 4958
    I think my stupidity was just responsible for a sticky...
    Go here be happy!
    Ratchet Garage e30 V8 build.
    • lambo
      Captain Scene Points
      • 10953
      Most people know about this, but...
      Here's a handy tool you can use to see how much bigger or smaller a tire is going to be compared to stock and how that will affect your speedometer.
      http://www.miata.net/garage/tirecalc.html
      • Xat1cZ
        • 2020
        these 2 are pretty cool sites too..
        http://www.1010tires.com/tiresizecal...r-snt-emty-str
        • AndrewBird
          The Mad Scientist
          • 11898
          This is also useful:
            • 37834
            Thanks guys!
            BimmerHeads.com
            • SkurtleyE30
              • May 2012
              • 23
              Originally posted by MR 325
              • Tire
              • Tire Width
              • Aspect Ratio
              • Diameter
              on the picture of you car, what wheels are those?
              • lambo
                • 10953
                I know I've seem multiple sites that have pictures of variously sized tires on variously sized wheels.
                This is one of them:
                Real photos of stretched tyres and stretched tires on wider rims, organised by exact size. See how any tyre and rim fitment actually looks before you fit.
                What are some others? I know there are some out there...
                • future rs
                  • Aug 2012
                  • 514
                  Also keep in mind for very close fitment issues that not all tires are the same. not every 225/50/16 is going to be the same. Some brands may run wider even though it may be a "225"
                  • VinniE30
                    • 2113
                    That's right.
                    And under tire width, contact patch should also be noted.
                    "This measurement is measured with the tire mounted and inflated to specifications from the widest point of the sidewall to the widest point of the opposite sidewall"
                    That means two tires could have the same "225" width, but one could have a larger contact patch than the other, for several reasons, like it being a summer vs winter tire or the tire having a larger or smaller aspect ratio.
                    Zinno '89 <24v swap in progress>
                    • lambo
                      • 10953
                      Found it!
                      Wheel fitment database
                      • Cronopoulos
                        • Jul 2011
                        • 2187
                        Also, with *most* R-comp or like R-comp tires... they run wider than your average street tire!
                        Project log -- DIRTY 30
                        2.7i * Megasquirt tuned * E85 powered
                        • decay
                          • 5637
                          Alloy Wheel & tyre fitment calculator - it calculates inset, poke, speedo error, tyre stretch and loads more.
                          past:
                          1989 325is (learner shitbox)
                          1986 325e (turbo dorito)
                          1991 318ic (5-lug ITB)
                          1985 323i baur
                          current:
                          • agent
                            Vice Grand Pubaa
                            • 7960
                            Best one I've found:
                            Originally posted by kronus
                            • future rs
                              • Aug 2012
                              • 514
                              Originally posted by VinniE30
                              That's right.
                              Thanks that's what I was looking for. Contact patch.
