16x7, ET35, what size spacers?
  • PaulZ
    • Aug 2005
    • 118
    I currently have 2 - 15mm spacers.
    1. Should I just get 2 more 15mm spacers?
    2. Should I buy 4 - 10mm spacers for correct fitment and sell the 15mm's?
    3. Should I keep the 15mm's and pick up 2 - 10mm's for the front?
    4. Will the 15mm spacers run closer to the strut or the wheel well?
    I would like to run a tire with a decent sidewall, not 205's or 215's, and my car is dropped 60/40 (Koni S/A's and Eibach Sports)
    Thanks!
  • redcarbon
    • Apr 2005
    • 213
    I have 16x7 et35 wheels and am running 10 mm spacers all around. I'm pretty sure you can run 15mm all around without rubbing, maybe not with 225s. You say you have the 15mm spacers, why not test fit the wheels on both ends and check for clearance.
    10mm will work, no problems at all. 15mm starts to get close to the fenders, you may need to roll them if you go with more than 205s. I know people on here runing 16x7 et20 (the same if you ran 15 mm spacers), but I don't know their tire size or if they have rolled their fenders.
    318is -gone-
    • PaulZ
      • Aug 2005
      • 118
      what size tire do you run?
      • Digitalwave
        is a poseur
        • 6298
        I have 16x7's ET40 with 20mm spacers (ET20 overall, same as you running a 15mm) and some 205's that run wide, and a 60/40 drop with no rolled fenders and no rubbing. With 225's and ET20, you could probably get away with rolled fenders and not rub. Depends on which tire it is though.
        RISING EDGE
        • redcarbon
          • Apr 2005
          • 213
          205/50-16 hankook rs-2
          318is -gone-
          • PaulZ
            • Aug 2005
            • 118
            so I guess the safe bet would be to run 10mm's at all 4 corners, and wrap them with 205/50's?
            • redcarbon
              • Apr 2005
              • 213
              like digitalwave said, you CAN run the 15mm spacers with a 205 tire. I would do that since you already have 2 15mm spacers. But if you want to get rid of the spacers and get 10mm ones, I'll take the 15mm spacers, I'd like to see what the wheels look like spaced out another 5 mm.
              318is -gone-
              • Digitalwave
                is a poseur
                • 6298
                No, 15mm is spenty for 205 tires but if you want to run 225's it will be easier with 10mm spacers.
                RISING EDGE
                • PaulZ
                  • Aug 2005
                  • 118
                  were can I purchase 10mm spacers? all I can find is 15mm's...
                  also, if I ran 15mm's in the back and 10mm in the front, would that be a problem? it would just have a wider stance in the back, correct?
                  • Digitalwave
                    is a poseur
                    • 6298
                    You'd be fine.
                    RISING EDGE
                    • PaulZ
                      • Aug 2005
                      • 118
                      anyone know where I can get 10mm spacers?
                      • Mystikal
                        Wheel Fitment Expert
                        • 9602
                        15mm spacers.
                        Know why? Because it's about impossible to find anything less than 15mm with a proper 57mm hubcentric lip, and without that you will have vibration issues.
                        15mm, front and back. 225's will work with rolling, if you want to. Anything less than that will mount without modification.
