MOMO Star Wheels 15x7 - Require hub rings?
  • txtorquemade
    • 1758
    Simple questions. Do the MOMO Star wheels require hubcentric rings?
    Anybody?? (please only answer if you're positive of your answer).
    Thanks!!
    sigpic 1987 325is
  • bastianshaw
    • Jan 2007
    • 2210
    measure the wheels bro
    • acolella76
      • 2950
      Is the hub bore of the wheel bigger than the E30 hub? If yes, you need rings
      Is the hub bore of the wheel the same as the E30? If yes, you DONT need rings
      TLDR: measure the wheels bro
      -Alex
      • txtorquemade
        • 1758
        Ok... for those that might be somewhat ....."challenged".
        Is the MOMO 15x7 Star KNOWN to require hubcentric rings? I have them mounted. They seemed to fit fairly tight on the front hubs, but the rear hubs seemed to be smaller than the wheel hub diameter. Doesn't make sense, I know, ....hence my question does anyone KNOW if they require rings. Was kind of dark when I mounted them and eh,...if their off it isn't by much. Car drove ok, but still... inquiring mind wants to know.
        sigpic 1987 325is
        • evandael
          • Oct 2009
          • 2881
          • delatlanta1281
            Dart Master
            • Mar 2006
            • 10317
            DUDE.
            MOMO made all kinds of center bores to fit all kinds of cars. Unless you know these were made for an e30, then you need to take a micrometer to the center bore of each wheel. The hubs on an e30 are 57.1mm, so, by that logic, what alex said is true.
            No one in this thread is "challenged" except for you.
            Yours truly,
            Rich
            you kids get off my lawn.....
