Rear noise with new wheels installed
  • nugentnsb
    • Jul 2011
    • 444
    When I put on my aftermarket wheel, there is a metal noise that gets faster the faster I accelerate.
    When I put stock Basket weaves on the noise is gone
    ideas? :(
  • reelizmpro
    • 9553
    Probably rubbing the caliper anti rattle clip and clearancing it (grinding). Check for signs of this.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Herr Faust Schinken
      • Feb 2012
      • 3580
      ideas? :(
      what wheels are they, are they hub centric, are you getting any vibrations too
      88 325is Five Speed
      Lachssilber
      • nugentnsb
        • Jul 2011
        • 444
        bbs rs 4x100 filled redrilled. and no the hubs wernt the same size, wheel hub bore was larger, but i only heard noise on the left wheel, right wheel was fine.
        • nugentnsb
          • Jul 2011
          • 444
          bump
          • ELVA164
            • 4861
            There was no evidence of a rub on the inside of the wheel like reelizmpro mentioned?
            • WhyNot
              • May 2012
              • 363
              could the different tires be making the noise, like if they are cupped from a previously bad alignment?
              if the rims arent hubcentric you should buy the reducers
              Originally posted by der affe
              What are you going to start a thread about next? "My woman's skinny jeans chaffe my special parts, f*ck skin irritation"
              Originally posted by navid41691
              And no, I use lotion so I don't have to worry about skin irritation.
              '...rolling balls, i'm elated, i'm going dumb now; drinking liquor i'm faded and having fun now; loaded gun and tripping with everyone around; keep me stuck in the sky, i never wanna come down...'...kabosh
              • CW325
                • Jul 2011
                • 1434
                I think its the bolts hitting the ebrake cables inside the hub. Had the same problem with my old wheels. Try throwing on a spacer and see if it goes away.
                • nugentnsb
                  • Jul 2011
                  • 444
                  thanks that was it!
