K1s really discontinued?? alternatives....?
  • rwh11385
    lance_entities
    • 18403
    Circle racing aluminum... (or steel if you feel like it)?
    Supposedly strong. And 13x7lbs for 15x8.
  • 2002maniac
    • 4260
    those are 'spensive
    • rwh11385
      lance_entities
      • 18403
      meh 15x8 koseis are $199 each. and these you can choose your offset, so never spacers. and hubcentric so no $ for centering rings
      cheaper than kodiaks, ccw's, etc
      • 155///MPH
        • 473
        Team Dynamics from Bimmerworld.
        DE's are a tease.
        Build a racecar.
        • rwh11385
          lance_entities
          • 18403
          7" width: Absolutely winnar. And also HMS Motorsport sent a mailer saying they sell them too.
          although in greater than 7" width, and reasonably affordable, and reasonably light... the market just got thinner. Ronals anyone like Randy Walters now?
          • Mystikal
            Wheel Fitment Expert
            • 9602
            Ronal is lacking supply too.
            Unless I'm racing for money, a 7" wheel with 225's is more than enough grip.
            • rwh11385
              lance_entities
              • 18403
              ...hmm, i guess that's why everyone else is running that too...
              • Mystikal
                • 9602
                Techincally, a lowered E30 on 225's will pull 0.90Gs.
                Seems sufficient.
                • Digitalwave
                  is a poseur
                  • 6294
                  Just look for Honda fitment and you will find an infinate amount of light and affordable wheels.
                  RISING EDGE
                  • rwh11385
                    lance_entities
                    • 18403
                    not many hondas are running 8" widths though....
                    they do have SSR Comps 15x7.5 (and Miata)... my uncle is an accountant at a machine shop and they could probably "adjust" the hub centerbore if necessary, or a BMW shop owner (Will's boss) suggested having them make custom spacers if I needed them (which I could then sell i guess). Find an engineering/CAD pal to design them... hmm
                    Of course, Team Dynamics with their 7" width would probably be FINNNNNNE likely.
                    • 2002maniac
                      • 4260
                      if you have clearance problems with wide 225's on your et17 Kosei's you could always have ~5mm removed from the mounting surface on a lathe. Would be very simple if the depth of the centerbore would still fit on the hub.
                      • Digitalwave
                        is a poseur
                        • 6294
                        Yeah but why compromise the structural integrity of a cheap rim when there are so many other options out there?
                        RISING EDGE
                        • rwh11385
                          lance_entities
                          • 18403
                          meh, i thought about it. but i am probably good on clearance anyway.... i am just a waffleswaffleswaffleswaffleswaffles that the tire will hit.
                          • 2002maniac
                            • 4260
                            If you've seen the inside of a Kosei you would understand. There would be no structural compromise.
                            • asubimmer
                              • 6482
                              I wish Team Dynamics had a black rim w/ a silver lip....not just black :(
