Z3 M Style 40's on an e30?
  • Viking445
    • Apr 2013
    • 99
    I have tried searching and can't find anyone thats done it. Wheels specs are 17x7.5 et41 and 17x9 et8 Doable with flares?
    89 320i Touring/M52 Swap w 4.10 Gears/K&N intake/Catback Exhaust/KW coils/Wilwood brakes/Azev A 16x7.5F 16x9R 215/40/16 F&R
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    Assuming you have a 4 lug setup and you need adapters:
    The fronts can be done. Use adapters (18mm min thickness for an overall offset of +23). rear, you'll have ALOT of poke, even with flares. I do not recommend. I recommend a square setup of the 7.5's only if you can do it, with adapters.
    if you have a 5 lug setup, then I don't have a freaking clue as I never had a 5 lug setup on an e30 before
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • Viking445
      • Apr 2013
      • 99
      I still haven't decided if i'm gonna go 5 lug. I'm in the process of buying a 325 touring from germany and then when i get back to the states (Navy) swap in an LS1 so i'm trying to find the widest staggered setup so i'm not completely traction limited lol
      • downforce22
        • Aug 2009
        • 3191
        bump, will these fit on 5 lug?
