spacer question
  • maniax101887
    • Feb 2006
    • 36
    spacer question
    i have a 15x7 et 37 on 205/50/15 with stock suspension what size spacers should i use. i really dont know much about sizing and i could use any type of help
  • 92 mtechnic cabrio
    • 4907
    with a seven inch wide wheel, I'm going to give you information based off of the sizing I have.
    my 7.5" wide wheel has an offset of ET42, I run 20mm spacers for a final 22mm offset.
    With your 7" wide wheel, it should be 6mm higher total, since your wheel isn't as wide. I know it doesn't make any sense, but I think I can still help. (Using the assumed, 25mm = 1", it distributes into both sides evenly, 12.5mm = 1/2", so ~6mm.)
    12mm spacers would look great on your car, but if you can't find 12, 10mm will work just as well. Just make sure you get matching extended bolts.
    R.I.P 07/01/09 - 04/23/10 :(
    • maniax101887
      • Feb 2006
      • 36
      thanks a buch do u knowe where i can get some
      • Digitalwave
        is a poseur
        • 6299
        10mm, 15mm, and 20mm would all work. They are about $200. I bought mine from www.turnermotorsports.com
        You need longer lug nuts as well.
        RISING EDGE
          • 37833
          15mm would be the perfect option in my opinion
          I am not offering that suggestion because I have some for sale but I am letting you know I do have a set of 4 brand new 15mm H&R spacers for sale :) PM me
          Grover Beach, California
          BimmerHeads.com
          • Mystikal
            Wheel Fitment Expert
            • 9602
            15mm for sure. It's impossible to find an actual hubcentric spacer any thinner.
            • Digitalwave
              is a poseur
              • 6299
              Nevertheless I still think 20mm would work fine if need be, especially at stock height.
              RISING EDGE
              • Mystikal
                • 9602
                Yeah, but it's always nice to leave the possibility of moving to 225's with the same equipment.
                And stop convincing people to cram tires into fenders, haha. How are yours holding up?
                • Digitalwave
                  is a poseur
                  • 6299
                  It's very rare that I hit them but the damage has been done, especially when I was running this setup:
                  You can tell the fender is wavy in this pic:
                  RISING EDGE
                  • maniax101887
                    • Feb 2006
                    • 36
                    do have to put front and rear cause i only need them fo the front cause there rubing on the strut and since im not put that big of spacers would oit make a differnce
                    • MrK
                      • Jan 2006
                      • 709
                      What's wrong with putting them front and rear? Cost?
                      This is your M20 on steroids:
                      • fitz318is
                        • 20
                        Use a 15mm HR hubcentric spacer and longer bolts from turner. HR's are money but you know you are getting quality, make sure to use anti sieze. I have the same set up. But your tires are the wrong size, 55 is what you want in a 205.
                          • 4907
                          It would be aesthetically unpleasing.
                          It would, if anything, make oversteer more apparent.
                          It would totally throw off something, I'm sure.
                          Just get two pairs, man.
                          • Mystikal
                            • 9602
                            If you really wanna be cheap and you're happy with the looks, you only need 5mm spacers up front to not touch the strut.
