Pros and cons of fill and drill
  • UpstateMike
    • Jul 2013
    • 218
    Anyone with experience with filled and drilled wheels?
  • cactusjacks1
    • Sep 2004
    • 1216
    Try search - their are many threads on this subject!
    [I
    • Poorboyz
      • May 2012
      • 2117
      I believe he's asking about personal experience and not the actual fill/drill process.
      Rebuilding since 07/06/2016
      Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
      Poorboyz Feedback Thread
      • einstein57
        • Jun 2007
        • 10780
        cons- tuner lugs required
        www.gecoils.com
        • Poorboyz
          • May 2012
          • 2117
          I didn't know tuner lugs were bad. What's wrong with them?
          Sent from my Galaxy Nexus using Tapatalk 4
          • UpstateMike
            • Jul 2013
            • 218
            POORBOYZ what is a tuner lug ?? I'm a newbie. Lol
            • UpstateMike
              • Jul 2013
              • 218
              Exactly
              • wazzu70
                • Jan 2005
                • 1143
                Con-wheels are generally considered strong enough to track with.
                Plus-for street wheels it is way faster and cheaper than a hub swap.
                -Nick
                M42 on VEMS
                • SmokeE30
                  • 1730
                  It's a lug nut with a smaller outer diameter to fit into smaller holes. Usually they are spline drive and require a matching wheel key to fit into the smaller hole to remove them.
                  As far as fill and drill people's opinions vary but everybody agrees they shouldn't be used for track use as most wheels people are fill and drilling arnt even forged. But many people feel comfortable with them on the street, I personally drive pretty hard on the street from time to time sooo yeah it's your call
                  Shawn @ Bimmerbuddies
                  Bimmerbuddies LLC
                  717-388-1256
                  2971a Roundtop Rd, Middletown PA 17057
                  bimmerbuddiesllc@gmail.com
                    • 37833
                    They are? Roommate has been running redrilled 16" style 5 for years with regular stud kit.
                    Grover Beach, California
                    BimmerHeads.com
                    • Poorboyz
                      • May 2012
                      • 2117
                      Does it matter what kind of style 5s they are or do all style 5s have the same 74.1mm center bore like the RC090 style 5s?
                        • 37833
                        Only E39 wheels have that centerbore. Others are 72.56.
                        BimmerHeads.com
                        • UpstateMike
                          • Jul 2013
                          • 218
                          I like the responses so far. Keep em coming!
                          • AwakenNoMore
                            • Dec 2010
                            • 1291
                            Been seeing quite a few sets of one-piece style 5's for sale locally for dirt cheap. Whats a fill 'n' drill running cost wise these days?
                            1991 325i - "Scambles" The Daily Driven lightly modded.
                            1988 Mazda RX-7 TII "Mako" The Free Dorito
                            bacon by Jared Laabs, on Flickr
                            • IRON-E
                              • 16548
                              Correct me if I'm wrong here but, this is my conclusion of fill & redrill, if I missunderstand or you need to add more accurate info, please do so.
                              Pros- You get the correct bolt pattern for your car, have tons of wheel choices & no longer being limited, to 4 lug wheel market.
                              Cons- If not done correctly, you will end up with major issues.
                              Center bore sizing has to be the exact diameter of the car you're installing the wheels onto., this requires hub spacers and like mentioned earlier, maybe switching to a stud conversion as opposed to lug bolts.
                              Good luck on your decision
                              @IRON-E30 aka Edwin:D
